Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: 04 Honda Accord Coupe LCD Install
  1. #21
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    Maryland
    I have a 2003 honda accord coupe v6, 6spd. I put a xenarc 7inch screen in my accord. I molded it where the center a/c vents are. you would lose youe center a/c vents but, it still blows cold air harder out the side vents after you seal off the a/c ducks. It was pretty easy for me to build this setup. because I have a car audio business, we can fab any thing. then I put my panasonic dvd/cd burner in the below pocket. I molded it in flush into the aftermarket headunit kit that replace the lower storage bin. I can build this front dash setup for anyone that has a accord. I just need the top a/c panel
    and I can get the aftermarket double-din hu kit.
  2. #22
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by customaudioman View Post
    You got any pics ???
    Even though I like your idea, but I don't wanna lose any of the factory functionality thats why the only two options for me are to either go with a single din screen in the storage area or do it like this (I'm not a big fan of doing it that way though)
  3. #23
    Oct 2005
    Maryland
    yes I do have pics. if you go with single din, your not going to be able to view it at that low angle.(storage area) give me a few minutes, I'll try to put up some pics. im not finish it yet, just have to prime + paint and im done. I my cpu in the trunk also. the only factory option you lose is that the air only blows out the side vents and the hazard button is relocated on the top. it still keeps my just as cool as before.
  4. #24
    Sep 2006
    Richmond, Tx: USA
    All, post some pics so that we can see
  5. #25
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    I have a 06 Accord SE sedan.
    I was thinking about the Metra 1Din center facia, but decided not to do that.
    Have you seen this?
    I don't know where you can buy the housing kit, but this is the PERFECT place for a 7" LCD.
    I folded a paper to the size of 7" screen and taped it there for a day. Just to see if it'll block the view..
    It doesn't block the view at all. (well, unless you are really really short)
  6. #26
    Oct 2005
    Maryland
    2003-2006 accord pics
    here are the pics
  7. #27
    Oct 2005
    Maryland
    more pics accord
    more pics
  8. #28
    Oct 2005
    Maryland
    these are older pics from a month ago. I will post some new ones next week sometime if I have time to finish painting the dash. And if anyone need me to build any custom parts, let me knowbefore the end of the month. I get real busy with customers build during the fall.
  9. #29
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    How did you mold your dvd drive so niceley, i had trouble with my console the drive kept on crushing and i couldnt put a cd/dvd in the drive. so this is what mine looks like in my 6th gen accord(98-02)
  10. #30
    Oct 2005
    Maryland
    on my dvd/cd drive I used an external drive case, which helps to support the drive. I just traced the face of the drive onto the place where its going to be. then cut the part out, build a platform behind so the drive has something to support the weight of the drive. then the face of the drive, you put threw the cutout part of the case. then you take some masking tape and tape up the face of the drive so you dont get body filler on it. put the filler around the edges of the face of drive. let dry for ten minutes, then push the drive back out of the case where it comes out the back and not the front. Trim bondo or filler while it not completely dry. then sand the area with 80 grit paper.
  1. Honda Accord Type-R Install almost finished!
    By l9nux in forum Fabrication
    Last Post: 02-09-2010, 02:16 PM
  2. 2003 Honda Accord Radio/Climate control Question
    By Underfunded in forum Newbie
    Last Post: 03-23-2006, 12:02 PM
  3. 2000 Honda Civic Dash LCD intigration
    By pcmofo in forum Fabrication
    Last Post: 03-20-2006, 12:09 AM
  4. Full install Honda accord aerodeck
    By ColonelB24 in forum Show off your project
    Last Post: 09-08-2004, 11:21 AM
  5. 91 honda accord install
    By mp3mike05 in forum Show off your project
    Last Post: 06-18-2004, 03:33 PM
