Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: 04 Honda Accord Coupe LCD Install
  1. #31
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by customaudioman View Post
    on my dvd/cd drive I used an external drive case, which helps to support the drive. I just traced the face of the drive onto the place where its going to be. then cut the part out, build a platform behind so the drive has something to support the weight of the drive. then the face of the drive, you put threw the cutout part of the case. then you take some masking tape and tape up the face of the drive so you dont get body filler on it. put the filler around the edges of the face of drive. let dry for ten minutes, then push the drive back out of the case where it comes out the back and not the front. Trim bondo or filler while it not completely dry. then sand the area with 80 grit paper.
    can you link me to where you got your external and which one it is?
  2. #32
    Sep 2006
    Albany,NY
    Here is what I’m thinking about pc in my 03 accord:
    I want to install 7" touch screen in the lower storage bin by modifying the OEM one - I want to keep the functionality to open/close. Here is a link to a similar setup FS: 05 Honda Accord Compartment Lilliput Fiberglass Mold . I hope there will be room underneath the LCD for a slot-load dvd-reader.
    I'm shopping for a touch screen right now…
    As far as PC I’m thinking of a laptop underneath pas. seat. I want to create a module which will automatically turn the laptop on, when the car starts and I want to make it hibernate when car is off (using the laptop battery).
    Audio will go to OEM stereo via aux in.
    Hopefully I will have enough free time and funds to finish this project before winter…
  3. #33
    Jan 2006
    The Colony, TX
    Quote Originally Posted by alertik View Post
    i have read people encountered more problems through a laptop then a desktop. thats why i did a desktop and i plan on keeping it permanent
  4. #34
    Sep 2006
    Albany,NY
    laptop is cheaper (~$150 with broken screen on ebay) thats why i'm sticking with it..
  5. #35
    Newbie HybridPower's Avatar
    Sep 2006
    Hmmm... I think you might be a lil hard pressed to get a dvd/cd drive under the screen area if its that type of set up...
    You could always set one up in the center console area. There's lots of room within that compartment
  6. #36
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by HybridPower View Post
    My initial plan was to go with a laptop too but after reading countless threads I came to the conclusion that desktop would be a better choice. Plus there are pre-build auto startup/shut down option available for desktop and thats VERY important for me.
  7. #37
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    Maryland
    slimline cd/dvd external case
    Quote Originally Posted by MegaloRESE15" View Post
    I got it from case-mod.com, but I dont think they sell them anymore. I will try to find another place for one.
  8. #38
    Oct 2005
    Maryland
    dont go with a labtop, just build a desktop pc. you will have less problems in the long run.
  9. #39
    Sep 2006
    Richmond, Tx: USA
    CUSTOMAUDIOMAN, wat motherboad are u using micro-ATX ?
  10. #40
    Oct 2005
    Maryland
    motherboard- mirco-atx with opus 150power supply
    Quote Originally Posted by ajamils View Post
    im using the intel d865glc micro-atx board. it cost around $70-$120 new from a online store.
  1. Honda Accord Type-R Install almost finished!
    By l9nux in forum Fabrication
    Last Post: 02-09-2010, 01:16 PM
  2. 2003 Honda Accord Radio/Climate control Question
    By Underfunded in forum Newbie
    Last Post: 03-23-2006, 11:02 AM
  3. 2000 Honda Civic Dash LCD intigration
    By pcmofo in forum Fabrication
    Last Post: 03-19-2006, 11:09 PM
  4. Full install Honda accord aerodeck
    By ColonelB24 in forum Show off your project
    Last Post: 09-08-2004, 10:21 AM
  5. 91 honda accord install
    By mp3mike05 in forum Show off your project
    Last Post: 06-18-2004, 02:33 PM
