Results 1 to 6 of 6
Thread: $1000 Budget, what would you do?
    Sep 2006
    Fort Worth, TX
    Question $1000 Budget - What would you do?
    Hello Everyone,
    First post - be gentle
    I've been lurking for some time now lots of GREAT information here! In fact, too much information - brain overload.
    First off I drive a Ford Lariat F150 Supercrew. I'm wanting to add a puter for Navigation, MP3 playback, DvD, TV, XM/Local Radio, and WiFI access.
    I have been looking at a few things on ebay:
    Car PC Kit-VIA SP13000 Mini-ITX MB, M2-ATX, VoomPC Case
    XM PCR
    Creative Soundblaster Audigy 2 USB
    Slot Load DvD
    Something like this for a FM Tuner
    I'm still at odds on a Monitor, not exactly sure what will fit, I'm thinking a 7 or 8 inch. I'm worried about buying the monitor off ebay as I would like to see the brightness and overall quality.
    Has anyone had any experience with the above listed, good or bad? It will be about a month before I start ordering everything and I'm just trying to get opinions on what I have selected so far as well as what I might need to add.
    I don't have to have EVERYTHING at start-up, just the essentials.
    So far I have:
    Microsoft Streets & Trips 2006 with the GPS receiver
    iNav Software
    Powermate knob
    WinXP Pro
    I will continue to as I'm sure there will be a lot of telling me to , is my friend.
    Thanks guys.
    BTW: I'm very flexible and open to any and all ideas. Flame away, I can take the bad with the good
    Semper Fi
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I'd get the 1.5ghz Jetway board (it runs pretty hot) from the same seller. I bought my 1.5ghz Jetway board from him a couple weeks ago, I'd recommed him to everyone. The only thing I would have done differently is I would've used the 12w version instead... but I didnt know about it at the time(the 12w version doesn't run hot like the 25w version) so...
    I'd get the Globalstat BU-353 reciever, because the one you have is ehhh.. I bought that one first too. I have the 353 under a bunch of metal in my truck and I lock on all sats. Great buy!
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Sep 2006
    Fort Worth, TX
    Quote Originally Posted by proph View Post
    I'd get the 1.5ghz Jetway board (it runs pretty hot) from the same seller. I bought my 1.5ghz Jetway board from him a couple weeks ago(the 12w version doesn't run hot like the 25w version) so...
    Thanks for the reply!
    I don't see a 1.5ghz at 12w in any of his auctions.
    As far as the GPS Receiver, your absolutly right, it sux to put it nicely but it will work for now. Once I get everything setup and installed I'll go with the
    Holux GR 240 GPS USB Bluetooth SiRF III
    The wife is having some concerns with this little machine, so I will be spending the bare minimum untill I can get it built and prove that it will be Groovy
    Last January I built a shuttle PC that set the budget back a little bit and she thinks I have too many computers as it is (is that possible?)
    Anyone have any other advice or comments on my setup thus far?
    Thanks!
    Semper Fi
    Jun 2006
    Looks like a good build. I would recommend the C134 case and computer (as it was the carpc I was going to use.) Already comes with ram, harddrive, and OS and they are great computers.
    FS: (C134) CarPC *$450*
    If you looking at buying.
    May 2009
    Marshfield, Missouri, United States
    $1000 or less.
    Hey check out my system, its cost me about 650 for everything on ebay
    Variable Bitrate csfile's Avatar
    Feb 2009
    I see you're looking at an HQCT. Just a suggestion, but you may want to look into an HD Radio. HQCT is expensive, and you can get a Directed DMHD1000 + mitchjs cable for ~$75. I've had both and the Directed unit gets better reception, but you may have better luck with the HQCT.
    Edit: Just realized this was a really old thread
  1. Chevy Metro Budget Carputer
    By c4shm0ney in forum Show off your project
    Last Post: 07-10-2005, 11:04 PM
