Results 1 to 10 of 19
Thread: What IDE Cable for Slimline Slot Load DVD?
    Jun 2004
    I know this is a complete noob question, and that is why its posted here. I just bought a c134/m100000 from a guy on here and it didnt have the ide cable that goes from the slimline adapter to the motherboard, when i owned my first c134/m100000 setup, i think the ide cable came with one of the components that i bought, regardless, I have tried like 3 IDE cables that I had laying around and none of them fit. Can someone plz point me in the right direction or give me a link to a IDE that will work. Thanks alot, I have searched and didnt find an exact answer.
    Elsewhere
    IDE cables are IDE cables....
    The only difference is whether it's 40-pin or 80-pin, the latter supporting ATA66 and ATA100 tranfer rates.
    It's likely not the IDE cable that's the problem, but the adapter itself or the drive that is the problem.
    How about the Wiki?
    Jun 2004
    hmmm, the adapter that converts the drive from a "laptop" connection to a IDE connection fits on the drive fine, if there are only 40 and 80 pin IDE cables, then I guess I was just using the IDE cable I had incorrectly?
    DIGItonium
    Guest
    There are no 80 pin IDE cables, but there are 40 and 44 pin IDE cables. 44 pin have smaller pitch, and the extra 4 pins are power.
    You are probably getting mixed up with 40 conductor and 80 conductor IDE cables (still 40 pin). 80 conductor IDE cables have extra ground wires to improve signal integrity when increasing data transfer rates.
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    DIGItonium, sometimes, the IDE cables have one small hole that is blocked off on one side. If you look at the center, you might see a hole blocked off where a pin fits in there. I encountered this when I bought a new IDE cable that was one of those "round" ones. I carefully inspected mine and determined that it was simply left filled in for whatever reason and I took my smallest drill bit and drilled it out. If you choose to do this and drill out the blocked off square, I urge you to BE VERY CAREFUL!! I was fortunate that I had a tiny bit and was successful in making it fit. I don't know why select IDE cables have this spot blocked off but I have since tried the cable and it transfers/runs fine. This may or may not be pertaining to what you are decribing but I figured I would offer some of my experiences with a ribbon cable that did not fit. Again, if this is part of your trouble and you decide to drill out the blocked off spot, be very careful and take your time.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    DIGItonium
    Guest
    ^ Good eye! Some 40/44 pin IDE cables have this tiny piece. Sometimes it's solid with the connector, and other times it's inserted. I was able to apply enough force to punch it through without bending the pin. In other cases, I literally cut this pin. It is marked "NC."
    Elsewhere
    My bad.
    I meant 44 pin. What was I thinking with 80 pin?
    That's what I get for posting past bedtime.
    How about the Wiki?
    Oct 2005
    St. Louis, MO
    Darque, I was a little curious myself. But I figured you just probably knew something that I didn't.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/showthread.php?t=85490
    DIGItonium
    Guest
    ^ Oops! Something was fishy coming from a mod
    I didn't know you posted the mistake ahah... time for a vacation maybe?
    The fun part is trying to get a longer than normal IDE cable, for example, to make the connection from the computer in the glovebox to a dash mounted IDE DVD drive. I've never done it, and I don't know what the signal integrity will be like.
    Jun 2006
    St. Asaph, UK
    just get an ide to usb adaptor.. you'd have to be crazy or stupid to run ide cable front to back in a car
    2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
  1. WTB: Slot Load DVD
    By djXternal in forum Classified Archive
    Last Post: 09-25-2005, 12:26 AM
  2. wtb: slot load dvd rom full size
    By EsKALad in forum Classified Archive
    Last Post: 08-30-2005, 12:08 AM
  3. Slim, slot load, DVD drive, where to get one??
    By JonEQuest in forum General Hardware Discussion
    Last Post: 06-23-2005, 02:58 PM
  4. Wtb - Slot Load Dvd / Cd Player
    By SAScooby in forum Classified Archive
    Last Post: 04-25-2004, 08:01 PM
  5. Pioneer Slot Load DVD Drive Shock Resistant?
    By Bloomk in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:46 AM
