Hi,
I searched around and couldnt find anything close to my issue, my apologies if this is in the wrong forum.
I recently modded my 05 corolla and installed a screen and a new
head unit, The screen is tapped into the ground for the head unit and the
power for the head unit, the screen is a Lilliput 7 Touch Screen Touchscreen my head unit is a JVC KD-ADV6270
The ground is on the metal tube in the dash and the hotwire is off the ignition switch.
The head unit is connected with a aftermarket wire connector that plugs right into the factory plug.
Everything was working great! today I got in my car and I had no power to the screen, head unit, clock on the dash panel or 12v outlets.
I checked all the fuses under the hood all of them checked out fine except two of them, I belive they were 10's, I dont recall the posistion of them right now.
The fuse on the head unit was fine, the fuse going to the screen was blown, and I also noticed that the wire for the screen had gotten a little hot and melted. I fixed that, replaced the fuse... and still nothing.. no screen, dashpanel clock, head unit or 12v outlets.
If I check the aftermarket plug going to the factory plug, there's no power with the key on.
The constant is fine and
lights up bright!
I didnt check the plug directly at the factory connector, But I'm sure that's dead as well.
Could it be possible I fried the relay? I would appreciate it if anyone could point me in the right direction or if someone had any further things for me to check.
I have a Chilton's Manual but it's not very detailed, I'm stuck,, bummed out and praying I didnt fry anything really bad... I do have all the lights on the dash panel still, the only thing that doesnt light up is the clock.
Thanks for any assistance!!!
Flomas
