Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: planning a build
    Sep 2006
    planning a build
    alright today at work we were throwing away some pretty decent computers so i picked up a small motherboard. its a intel 4000792
    heres some specs:
    Key Features
    Form Factor What is this?
    Micro ATX
    Compatibility PC
    Chipset What is this?
    Intel 845G
    Compatible Processors Intel Celeron, Intel Pentium 4
    Front Side Bus Speed 533 MHz
    Technical Features
    Integrated Input/Output Ports USB 1.1 x 6 • Serial Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
    Expansion Slots What is this?
    AGP x4 x 1 • PCI x 3
    Storage Controller Type(s) DMA/ATA-100 (Ultra) x 2
    South Bridge Chip Intel ICH4
    Processor
    Socket Type What is this?
    Socket 478
    Max supported CPUs qty 1
    Memory
    Memory Type What is this?
    DDR SDRAM
    Number of Memory Slots 2 x 184 Pin DIMMs
    Supported RAM speeds 266 MHz • 200 MHz
    Max Supported RAM What is this?
    2 GB
    Audio / Video
    Video Interface What is this?
    AGP 4x
    On Board Graphic Processor Intel Extreme Graphic
    Integrated Graphic Card Integrated Graphic Card
    Audio Output What is this?
    Line Out
    Integrated Audio AC97 Audio Codec • AD1981B Codec
    Audio Input Microphone Jack • 1 x Line In
    Video Out Ports 15 Pin D-Sub VGA port x 1
    Other Features
    Other Features Chassis intrusion detection
    Fans 3 x 3-pin fan headers
    Chassis Type What is this?
    Desktop
    Package Qty 1
    Dimensions
    Depth 8.2 in.
    Width 9.6 in.
    Miscellaneous
    Power Configurations ACPI/APM Power Management • Wake On Ring Header • Wake On LAN Header • Suspend to RAM • Wakeup from Keyboard/Mouse • Power-on Mode Control • Suspend to Disk (Hibernate) • Real Time Clock Wake-up Alarm
    what im wanting to know is was this a good find... and where do i go from here... im wanting maybe some arcade emulation but deffinately want gps, and dvd play... thanks guys...
    btw this is for a 99 chevy cavalier
    Elsewhere
    Next you go here: http://www.mp3car.com/vbulletin/the-faq-emporium/
    Read a lot. Learn as much as you can. Plan your setup thoroughly.
    Good luck.
    How about the Wiki?
    Sep 2006
    so i guess the mother board is ok to use...
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by darkdrake View Post
    as long as you can power it/make it fit
    ANYTHING will work
    motherboard/ram/hard drives.., they all will work
    mind you, most people try to go low power, since visual performance isnt really why people build carputers in the first place
    Sep 2006
    im not very familiar with the power supply thing... i was thinking of just using the one from the computer itself....
    does anyone know anything about this board or know why it wouldnt work...
    Apr 2005
    read the FAQ's
    You can't just plug in the motherboard into a power socket and be on your way...
    any computer parts will work inside the car, just like any computer parts will work in your home.
    powering it/mounting it are all issues that are very different in the car from in the home.
    Sep 2006
    im reading the faq's right now... im just not sure if this cpu will kill my electrical system or not...
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Make sure you read the "Power supplies - explained" thread, then.
    It is unlikely that CPU will kill your electrical system, but make sure you have a good idea of what you're doing before you wire it up. Read about selecting the proper wire gauge size and ensure that you fuse it properly as well.
    Want to:
    Sep 2006
    well fellas heres my newest dilemma, i can either use the board listed above, or i can use a gateway solo 2500 that i ran across today... it admit the 2500 doesnt seem to be big enough for what i want, but would also be easier to install and wouldnt have to go through the power supply dillema...
    so which would you prefer, i can get pc parts for relatively cheap if not free, (im an is tech) so far i havent spent any cash... and ive picked up a 40 gig hard drive... so.. what do ya think.
    Sep 2006
    thought maybe i should list what im wanting this pc to do.
    GPS
    MAME
    EMULATORS AND ROMS
    DVD,VCD,SVCD PLAYER.
    i think that about covers it. ill still be running my pioneer premier headunit for music and sirius.
  1. Does anyone want to build a fiberglass mold?
    By SecretSpyder in forum Fabrication
    Last Post: 11-09-2007, 04:10 PM
  2. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  3. Replies: 4
    Last Post: 08-28-2006, 09:30 PM
  4. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 12:00 AM
  5. Boot Build Planning Advice
    By andy@ukcars in forum Fabrication
    Last Post: 06-16-2005, 07:03 PM
