Results 1 to 8 of 8
Thread: Powering External Hard Drive from M2-ATX
    Mar 2006
    NY
    Ok, I'd like to have some good storage space for my carputer. Now, I was thinking of going with just a basic 40gb 2.5" hard drive on my via board for Windows, programs, etc. I'd like to add a 3.5" for media. Obviously the 3.5" are much cheaper per GB. I've seen the external cases that convert to usb so I could use that but they all seem to have a power cord. Is there a way to power this using my m2-atx? Can anyone point me towards how to achieve that. I tried searching but there's so much info here I couldn't seem to nail the right keywords for this.
    Thanks!
    Chris
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    They all have a power cord because USB has 5V to power devices. 3.5 hard drives need 12V. You can get 12V from your M2 yellow wire, but be careful not to exceed its rated output. M2's are known for causing all sorts of problems if you overload them.
    ~Jimmy
    Mar 2006
    NY
    So what would I need to go from the ac power cord to the 12v from the m2?
    Dec 2005
    Raleigh, NC
    I already do this off of my M1-ATX. Basically all you have to do is hack off the transformer from the external hard drive and wire that side up to a molex instead. Please pay attention to get the polarity right though, I'm sure you external hard drive wouldn't appreciate negative 12 volts when it is expecting positive.
    Basic illustration of power cord:
    Wall Outlet ------- Transformer ------- Hard Drive enclosure
    _____________________________^cut here (wouldn't allow spaces)
    The easiest way to get the polarity straight is to plug the thing into the wall and test with a multimeter which wire coming out of the transformer to the HD is + and which is ground (your multimeter will read 12V if your red lead is touching the + line and -12V if your red lead is on the ground)
    Mar 2006
    NY
    Great. I have one more stupid question. Everyone keeps mentioning molex's. I assuem this is the pin looking thing to connect to the m2? I did a search for molex connectors and there's like 15 different ones. Can you tell me which I'll need to conenct to the m2 and where on the m2 it would get connected?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    Quote Originally Posted by ckny View Post
    if u need to ask this.., then i really dont think you're qualified to install this
    kidding, anyway, the molex's we all talk about, are the same molex plugs that plug into hard drives (4 wires, 2 black, a yellow and a red)
    yellow = 12v
    red = 5v
    black's = ground
    so basically, hack the transformer off, hook the positive line to the yellow wire, and the negative to either of the grounds, and there u go
    Mar 2006
    NY
    excellent. thanks!
    Dec 2005
    Raleigh, NC
    http://en.wikipedia.org/wiki/Molex_connector
    You'll probably want to put a male molex on that cable with the Yellow (12V) and Black (Ground) wires running to the appropriate places on the HD enclosure power connector.
    * EDIT *
    I'm too slow. Sorry, I'm at work...
  1. Problems with a #@$^ing external laptop drive enclosure
    By wardemon666 in forum General Hardware Discussion
    Last Post: 09-07-2006, 07:22 AM
  2. $44.99 Olympus S-HD-100 40GB External Hard Drive
    By michael_16j in forum Classified Archive
    Last Post: 06-27-2006, 09:14 AM
  3. External Hard Drive Powerdown?
    By fatejd in forum Hardware Development
    Last Post: 01-28-2006, 01:15 PM
  4. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 12:50 PM
  5. External Hard Drive
    By Mr.Robotto in forum General Hardware Discussion
    Last Post: 07-19-2004, 11:12 PM
