Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Does my car have enough "power"?
    Sep 2006
    Rutherfordton, NC
    Hey guys,
    I have a 2004 Honda Civic EX and I was curious wether or not my car has enough power to run the components I want.
    I noticed that if I am in neutral with my lights on bright my lights will "brighten" when I give it some gas. This is barley noticeable but leads me to this question.
    I plan on running a carputer with one of the higher OPUS power supplies (180w?). I also plan on having 1 amp running my existing speakers and another running maybe 1 or 2 10-12" subs (not sure yet... im not looking for a lot of power). I will also be installing an EQ.
    What do ya think? I don't want to put a lot of stress on my battery and alternator. What are my options? Don't the make sure sort of large capacitors just for this problem?
    Thanx in advance!
    Elsewhere
    Moved out of the FAQ Emporium.
    Don't post there unless you have an infomrational post to share.
    Opus doesnt make a 180w PSU.
    Since your lights brighten when you hit the gas, it indicates the battery may be flat, since the alternator kicking in provides more power.
    If you take the battery to AutoZone or O'Reilley or any other major auto parts chain, they'll test it for free.
    How about the Wiki?
    Sep 2006
    Rutherfordton, NC
    Woops sorry,
    If admin could move it I would be appreciative.
    I had my battery tested and its perfect, the Honda dealer also said this was normal.
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    my 01 civic powers a 200 watt opus, a 1600 watt (max) audiobahn amp, a 50 watt 3 way crossover, and a 400 watt alpine amp.
    I can't say how well your battery will take it, because i upgraded mine to a optima yellow top, but i can say that my alternator takes the strain fine.
    I would also advise against a capacitor, you could try the "big three" upgrade. Search the forums for it.
    REBUILDING!!
    Constant Bitrate avengerki's Avatar
    Mar 2006
    Oregon
    Why would you suggest against getting a capacitor? Aren't they supposed to help maintain a level voltage and provide protection against suddens surges or dips.
    Avengerki
    PC Install: 85%
    Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
    Software install and setup: 35%
    Entertainment Package: 85%
    Aug 2004
    Yes, I would recommend against purchasing a capacitor. Many people see them to be "band-aids" myself included. What makes you think you need one?
    heres a link to the "big three" upgrade: http://forum.sounddomain.com/forum/u...=5;t=007801;p=
    REBUILDING!!
    Mar 2006
    Oregon
    For me I dont really see the need although I have thought about it. But then I've also put a higher output altenator in my car and keep contemplating doing a dual battery setup with a capacitor tossed in for line conditioning. But I know I tend to overkill the power side but I also always look at what I might use in the future and try to prevent having to upgrade something I just installed a month ago. And I have also done the top-three that you mentioned.
    Edit: Personally I wouldn't be using the capacitor as a band-aid so much as an insurance policy against a sudden surge.
    Avengerki
    PC Install: 85%
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    well... i expect Shadow to weigh in any day on this, but I'll give my thoughts on the matter... capacitors I think people look at with too narrow a scope. All anyone really sees is the issue of "can it support my massive subwoofer when my alternator/battery can't?". The answer to that is invariably no. You have to remember that for every watt you get out of that cap, you have to put another watt, plus efficiency losses back in. So if your power supply is insufficient to begin with, a capacitor just delays the inevitable.
    So what the heck good IS a capacitor then? Think in terms of the system-wide effects. Amplifiers generally perform best and coolest when supplied with ample voltage. Usually manufacturers bench test and rate their amps with a 14.4v regulated power supply. Compared to our cars, this power is awfully clean and devoid of any of the fluctuations in voltage imposed by other devices like defrosters, headlights, wiper motors, fuel pumps... A capacitor can help smooth out or eliminate these fluctuations PROVIDED that your alternator is supplying adequate current for all your devices.
    So do the math, if your amplifiers are 50 percent efficient, and you go somewhat conservative on RMS power and get 50x4+500x1. 200+500 watts at 50% efficiency means you could conceivably be drawing 1400w which at 13.8V (assuming your alternator maintained that voltage), is over 100 amps. I am reasonably certain that your average import passenger car is not going to supply you with much more than 80 amps... and remember, that's gotta run the car and all it's accessories too.
    So how do you get around the power problem? You've got at least two possibilities:
    1. You muscle through it. You buy a 170 amp alternator for $600+ and then start spending $1+ per foot of 0-gauge wiring which you have to somehow run under your car or cram under your carpet, not to mention all the wiring under the hood you'll have to replace so that the new alternator can deliver that kind of current without burning wires... plus the cost of whatever amplifiers you get.
    2. You plan for efficiency. First thing to check out is whom you would like to buy a full-range class-D amplifier from. Traditionally, class-D amplifiers have been unable to cleanly reproduce high-frequency sound, but there are a few companies, including Bang & Olufsen who produce high-end, high efficiency full range class-D amplifiers. These are typically 85-95 percent efficient. So, we'll take mine for example since i know it's specs off the top of my head: 50x5+300x1. That's 500w for 4 speakers and a sub. At 95% efficiency i'm going to be drawing about 38 amps at full tilt. My alternator produces a maximum of 80 amps, and the car takes about 40 of that. Cutting it close for sure but then the music isn't cranked to 11 on every dial either. At the levels i'm comfortable listening to, i'm only drawing about 6 amps. That sort of thing won't even phase your stock alternator.
    The next thing if you're adding a subwoofer is to pay attention to it's sensitivity rating. Manufacturers have various methods of arriving at this number, so don't take it as gospel, but it can help in determining which speakers can produce the most volume for the power you are giving it. Again, the louder your system sounds at a particular volume level, the easier you're likely to go on the amps.
    So back to capacitors, what good are they? Well again, maintaining voltage is key. Lets assume for a moment that your alternator can handle the complete electrical needs of your audio and vehicular systems. The mere act of turning on a device will create a voltage drop, drawing sometimes twice as much current as it's rated for for an instant. An appropriately rated capacitor can temporarily supply your entire electrical system with additional power to maintain that constant voltage, rather than succumb to a voltage drop. Voltage drops do two things, and the extent of which depend on the severity of the drop, but your lights may dim, and your sound quality may suffer. This is what capacitors are good for.
    So to sum up that longwinded rant: capacitors are NOT a power generating device. if your alternator can't keep up with your amps, a capacitor, no matter how big, will not help. Think efficiency before just strapping on bigger batteries and alternators. Because if your alternator CAN supply the power you need, then a capacitor will do just the trick to help you get the most out of your amps.
    Sep 2006
    Rutherfordton, NC
    Thank you for the replies, special thanks to GoHybrid for being so in depth.
    I belive the car will take the carputer just fine and depending on the sub I install I belive I will go ahead and do the "Big 3".
    Another question for ya, is there any difference in Power Blocks? Brand, things to look out for?? They just seem like a simple way to distribute power and in a efficent way with fuses.
    Thanks again!
    Jun 2006
    Denver, CO
    power distribution blocks are definitely convenient. brand doesn't really matter. all you're buying is a fancy gold or chrome plated chunk of metal... maybe fuses come with it, maybe not. Just make sure that it is rated to handle all the various wire gauges you will be using, that it has enough terminals, and that it comes with some sort of cover (and why wouldn't it?!) to protect it from whatever might land on it and cause it to short.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 12:36 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Employee Discounted Cars: Flatout BIG LIE!
    By sdashiki in forum Off Topic
    Last Post: 10-31-2005, 06:53 PM
  5. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
