Results 1 to 5 of 5
Thread: Can you please check my system and power reqs?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Here's my setup as it sits on my hot bench:
    - Morex 3677B Case
    - Mini-ITX VIA EPIA M10000 Motherboard
    - Embedded VIA C3 1Ghz CPU with Fan
    - 512MB PC3200 DDR Ram
    - Hitachi 30GB 2.5 Hard Drive
    - DVD/CDRW Slim Slot Load Drive
    - Creative USB Sound Card
    - OPUS 150W Power Supply
    - USB 4 port Hub
    - Xenarc 7" 700TSV
    I want to clean up my CarPC package by deleting the USB soundcard, delete the 4-port USB hub, and put the mobo and Opus 150W in the same case. In addition remove and remote locate the DVD drive into my dash w/ the PC in the trunk. To replace the deleted USB components, I'm planning to add:
    VIA 1 to 2 PCI Riser Card
    - one for additional USB ports (4)
    - another intergrated SB PCI card to replace USB SB card
    - BU-353 GPS Receiver
    Given the removal/replacing of components are almost one to one +/-2W, the Opus 150 should be able to handle all that just fine. I used the online power calculator to get a worst case 120W draw from the system. This is about all I want to get out of my CarPC.
    Before purchasing/installing the said components, can someone just please check the math if it is, in fact, okay?
    Again, newbie, says it all.
    TIA!
    Elsewhere
    You'll be fine w/ the Opus 150w and that setup.
    How about the Wiki?
    Aug 2006
    Sun Diego
    Thanks!
    Elsewhere
    Did you read this FAQ: FAQ: Will <insert PSU model> Power Supply work with my system? by any chance?
    It's good reading.
    How about the Wiki?
    Aug 2006
    Sun Diego
    I did actually. I read that and applied the info prior to posting.
    Since this is my very first attempt at building anything-computer related, I just needed a little reassurance from veterans. Especially since this is going into my car.
    I'm on a steep learning curve, but I am learning fast...
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Why people use mini-itx boards.
    By IntegraKarim in forum General MP3Car Discussion
    Last Post: 03-26-2006, 03:47 AM
  3. Easiest Way To Check System Power Usage?
    By James141 in forum Power Supplies
    Last Post: 03-09-2005, 06:07 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
