Results 1 to 10 of 20
Thread: My Planned System, Opinions Needed
    Oct 2006
    Hello I am planning my first setup and was origionally going to make a desktop fit into my car until I was shown this forum that let me see the light. So many of the problems I had with my previous idea were solved by the psu alone lol. Anyway here is my plan:
    VoomPC Car PC Enclosure
    (placed in the glovebox of my miata)
    VIA EPIA MII10000
    (with IDE riser to 2 IDE ports)
    M2-ATX PSU
    (plan on buying the atx extendor to cut down on temp/cables for IDE room)
    1gig DDR226 Ram
    WD 120gig 5400rpm Laptop HD
    (need IDE converter to run this HD)
    Linksys Wireless G Card (already own, might have to buy new antenna)
    Creative Audigy 2 ZS (already own)
    LiteOn 16x DVD Drive
    (plan on running cables out case and hand/place dvd-rom right near case)
    XENARC 700IDT Indash 7" LCD Touchscreen (don't like a big steal me target)
    Mouse/Keyboard options are being planned and don't matter much yet
    I have 2 remaining questions I could not find on my own.
    1. Is there enough room in the case to have the 2 IDE riser and use both those cards??
    2. If that all fits is that going to be too hot to run safetly? Just want to know ahead of time if I am going to have to mod case to add a good fan.
    So that is the plan I have right now for the computer. Tell me please if I am overlooking anything that I am going to need. This computer just needs to be able to play music while I use navagation (or another carputer tool) without slowdown and run DVD's without slowdown. As far as I have read so far this should be just fine for all that. This carputer will also be hooked up to my stereo of course that will be built at the same time in the trunk.
    I look forward to your input, hopefully I did my homework enough before posting this to get past noob questions and ideas.
    Chris
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    as far as i know, the VoomPC case is MUCH too small for a riser..
    even if the riser did fit, theres nothing to mount the PCI cards to, so they'd probably break either the mobo/themselves or the riser
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Wilsman00 View Post
    how are you going to secure it? do you know for sure that you have enough room? enough room including all cables?
    VIA EPIA MII10000
    as stated earlier, don't think the voom case can hold a riser...besides that, what do you need two ide ports for?
    look around, they exist and are readily avaliable.
    is this for the IDE ports? I don't believe it would fit in the case, let alone does that case have room on the back side of it for the cables and antenna to exit from?
    how do you plan on going from this card to your stereo?
    how are you going to secure this? is this a full size drive or a slim laptop drive? if it's a slim drive, do you have a converter for the cables? are you running an external case? do you have room for this, all of the cables, and the motherboard in the glove box?
    installed properly, just about everything can be hidden and well integrated. Do you know for sure that you have the depth that this unit would require behind your dash?
    Welcome to the boards. It looks like you have done a good deal of research and have thought out yoru plans. The points I have mentioned are points that most people overlook in their planning.
    Let us know if you hae any questions!
    Jan Bennett
    Oct 2006
    Thanks for all the good info/questions.
    There is plenty of room in the glovebox for the case + cables.
    Most likely I will mount the cse upside down to the room of the glovebox area either with screws or industrial velcro.
    The 2 ide ports were for sound/wireless card. But if it is too high then I'll have to get another type. Would a usb style one be my best bet? The kind with a antenna I could move around?
    The card to the stereo is the same as the example I found on these forums. Plan on running the mini stereo cable from the card back into my trunk where it will split up into the needed cables. Or have it split to rca's and then go back into trunk, I haven't decided which order would be better yet.
    There should be room for the dvd-rom in the dash. If not I can get a little creative. Origionally I wanted the Touchscreen in the bottom of my 2 available slots on my dash and the dvd-rom on the one above. But I wasn't sure if I could find a power cable that was long enough to get that far. Found several round ribbon cables that were fine distance wise but the power cables that come on that psu are so short I am not sure how I would power it. That is why I decided on in the glovebox as well.
    I need to goout and measure the depth I have for the screen, good point I forgot about that one. It should be ok but we shall see.
    Thanks Again
    Chris
    _
    Mar 2004
    Little Elm, Texas
    have you researched how poor the sound quality is when you split the signal like you are planning to?
    as for power cables, extend them. It's something you're going to be doing a lot of with this project, so prepare yourself.
    Jan Bennett
    Feb 2006
    Vancouver, BC
    Here's a really good write-up on putting everything into a VoomPC. From the pics you can see just how little space there is in it. Hope this helps.
    http://www.cartft.com/support/doku/m..._M2-ATX_en.pdf
    Oct 2006
    Ooh thanks for the pictures that is great!
    As for the sound quality I was very concearned with that. But since it was on here as a sticky I thought it would suffice. What other options do I really have? The sound car I have has normal stereo outputs and 1 coaxial if I remember correctly.
    Thanks for the help.
    Oct 2006
    By those pictures it doesn't even look like I can use a PSI card in that case. Am I not going to be able to use the sound card? Cause I doubt the sound quality of the on-board will be what I need. But then again maybe the cables wont be either.
    Sound quality is huge to me so I need to find a solution to this before I buy anything. I am willing to change options as long as the quality is top notch.
    Thanks Again
    Chris
    Aug 2006
    Thanks Again
    Chris
    this may only hold true to Amps, so correct me if im wrong, but its probley not a good idea to mount it upside down because heat rises and even with a fan the circuit board will take on more heat, possibly too much in some cases...
    im a audio man, so feel free to correct me
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    You might look into using a Creative Labs MP3+ external USB sound card. That was what I opted for and it seems like the sound is quite acceptable. I have my Creative connected to my VIA Mobo and then going to my head unit Aux input. From there, I have the head unit outputting RCAs to the four channels on my amp and then my sub channels. I haven't heard the system fully functional yet but I have noticed how well the MP3+ cleans up my songs. For less then $50 it was a decent investment.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
  1. Your opinions on this alarm system?
    By pastypyro in forum General Hardware Discussion
    Last Post: 10-26-2005, 09:52 AM
  2. Security System thoughts
    By techy101 in forum General MP3Car Discussion
    Last Post: 07-28-2005, 04:42 AM
  3. FS: Complete bmw e46 carputer system
    By RiXst3r in forum Classified Archive
    Last Post: 07-19-2005, 09:28 PM
  4. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
