Results 1 to 7 of 7
Thread: K301 / MTSVO-SC wiring problems.
    Low Bitrate Shidoken's Avatar
    Jun 2006
    Hi,
    I'm trying to do a bench test with the k301 by connecting the pc power brick to the cnx-p1900. the power up runs fine when i short the ignition line from the cnx to the power line but the thing is, the monitor doesn't seem to turn on. i see a fuse holder with some small pair of "5v fuses inside?" from the monitor's yellow wire. do i have to short that too to turn on the monitor?
    first time doing something like this but there's no write up on these monitors.
    i'll have some pics of what i'm talking about later tonight.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Both the red and the yellow need to have power to them for the monitor to come on, and of course you need to have ground going to the black. I cant remember which way round the wire colours are (red/yellow) but one is permanent power and the other is switched acc power. There is a huge sticker on the top of the 301 that will tell you which way round they are.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Jun 2006
    wait.. so the yellow (which on mine has a fuse and says +12DC on the sticker) and the red (Accon) have to have power to it? can i just tie them together to the same power source? and when you say switched acc.. that's ignition right? but it just stays on for a second....
    Jan 2005
    Scotland
    to test it yes you can tie them together but you will have to put the yellow to the battery or permanent supply and the red to a switched supply, ignition. If you put them both to a permanent supply it wont switch off properly or if you put them both to a switched supply it wont remember its settings.
    Jun 2006
    alright.. everything's working now but sometimes when i just do this bench test, the screen opens in increments when it's completely open or closed. i've noticed that it does this when it's been on for a while and when it's off completely then on again, it doesn't do that...
    does this happen to others? is this normal? is the speed of this thing set? it's kinda slow when it opens and closes..
    Jan 2005
    Scotland
    speed is set and when its wired properly you can use the up down buttons to set the angle of the display. When its switched off and back on it will go back to where you set it.
    Jun 2006
    alright.. seems everything it working now.. thanks for all your help scimitar!
  1. Problems in Wiring Amps
    By ideiafix in forum Car Audio
    Last Post: 03-31-2006, 03:44 PM
  2. Wiring XM Direct internally to motherboard COM port... Having problems
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:57 PM
  3. Hirose wiring problems
    By ddt in forum LCD/Display
    Last Post: 03-11-2003, 06:00 PM
  4. psu wiring and other problems
    By kardas in forum Power Supplies
    Last Post: 01-07-2003, 03:27 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
