Results 1 to 7 of 7
Thread: windows nt has not found enough extended memory
    Oct 2006
    sigh, well after extensive testing, i was wondering if anyone has encountered a problem installing an os on an epia m10000 mobo with a fresh unformmated hdd.
    i get past the POST just fine, memory tests are good, boot from CD starts fine from bios, the screen refreshes to the point of where it inits the cd, cdrom light working.. but then nothing happens, cdrom stops and the cursor just blinks in the top right hand corner.
    after alt+ctrl+del a few times here and there to double check the boot sequence, i get a message says:
    "windows nt has not found enough extended memory. 7mb of extended memory is required to run windows nt. you may needed to upgrade your computer or run a configuration program provided by the manufacturer."
    memory map:
    00000000 - 000A0000
    00100000 - 1DFF0000
    sometimes this comes up, other times its just the cursor blinking.
    has anyone encountered this problem in the past?
    any help is much appreciated, thanks in advance.
    im keeping a log of things ive done to double check the install:
    after keyword searching various terms from this response ive tried the solutions offered...twice over...still no positive result
    all cables tested, and working
    ram seating, and software tests, compatiblity checks, working
    parts testing on my desktop (ram, cables...etc) everything looks good, working
    power up is good... hdd access
    bios settings i didnt play with (only the hardware boot order - awardBIOS 2002. 2004 is latest but i havent updated it)
    Oct 2006
    updated my bios, didnt help
    if anyone has any suggestions, let me know
    Low Bitrate tC_install's Avatar
    Nov 2005
    Sounds like you have a bad ram stick.
    Check this thread : (EXTERNAL)
    Scion tC 2005 with DWW-700H
    Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
    Oct 2006
    thanks for the response, i took the sticks out of my desktop (corsair 1gb 3200, 256mb pc2100) and tried with them, same exact result...*sigh* i even put the 0.8 memory into my desktop, which i have in there now, its working as i post on this board...
    is there a chance the motherboard could "work" but be broken? meaning, would i get past the POST in any situation that wouldnt report an error?
    my next step is to take the whole freakin thing apart, and methodically check each cable, each piece of hardware, before i put them on the mobo
    Oct 2006
    sigh, so i bought a new motherboard, after thinking it was bad, everything else seems to be working fine, but still same error...if i keep this up soon ill buy a whole new car pc and have
    Oct 2006
    turned out, i was using a aopen dvdRW to install windows, as soon as i installed a regular dvd rom, all was set...
    hope this helps someone else in the future
    Oct 2008
    try replacing your ram memory card..
    i have the same problems in my pc..
    ive tried everything.. i even resulted to formatting it but it didnt work
    i cant boot from my cd rom, so it was impossible for me to format my PC..
    lastly, i tried replacing my
    ram card with my older ram card(older but still functional)..
    then it worked!!
    it booted perfectly..
    hope it willwork for you guys too!!
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  3. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 06:09 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
