Results 1 to 9 of 9
Thread: Build planning - How's this look? Comments?
    Low Bitrate kireol's Avatar
    Oct 2006
    Royal Oak, MI
    I plan on putting this in my quadcab 05 Dodge Ram
    I've done a ton of reading and tried to learn from others. I spoke with mp3car today and they were really helpful. Going to be ordering what I can from them. Here's what I think is going in. Will this work? Anything that I'm missing? The case I'll be making myself. The sound will be going into an aftermarket head units auxillary RCA jacks from the sound out of the motherboard.
    PC CHIPS A31G (V1.0) w/XPM 2800+ AMD Athlon XP Mobile 2800+ Socket 754 SiS 761 GX Micro ATX Motherboard/CPU Set - Retail
    -Onboard sound/video/usb
    CORSAIR XMS 512MB 184-Pin DDR
    80 Gig PATA WD 3.5"
    NEC 16X DVD±R DVD Burner Beige IDE Model ND-3550A
    Xenarc 700TSV - VGA Monitor with touchscreen and video inputs 7"
    M2-ATX 160W Intelligent DC-DC PSU
    BU-353 Weather-Proof GPS Reciever USB
    Thanks.
    Elsewhere
    It looks like it will work....
    For aesthetic as well as lower power draw, you might consider replacing the full-sized optical with a slim one. Another suggestion for optical drives is a slot-load drive. The trays are notoriously flimsy, and putting a disc in while driving could result in a useless optical drive with a broken tray.
    As a general rule, I avoid PC-Chips motherboards. I've had bad experience with them. You may not feel that way. It's just a personal opinion.
    Be sure to take lots of pics of your install.
    How about the Wiki?
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    I second DarquePervert's reccomendation not to go with PC Chips.
    I believe another member on the forum bought that motherboard, and it turned out that the amd "mobile" athlon xp, turned out to be an underclocked desktop athlon xp.
    Also, have you thought of where you are going to mount it?
    REBUILDING!!
    Oct 2006
    Royal Oak, MI
    ill look for another MB and cpu then. and consider the cd change. thanks.
    location is the easiet part of my project. pc goes under the middle front seat bottom.
    Aug 2004
    just checking, since depending on where you put it, you may have to get a whole slew of extension cables
    REBUILDING!!
    Oct 2006
    Royal Oak, MI
    Cool. thanks.
    Well now I'm having problems finding the right CPU and MB then since you guys are suggesting a new one.
    The one I listed is $80 shipped for CPU/MB/and fan. with onboard everything.
    Can anyone please suggest what would be something close to as fast or faster than this combo, that would be more reliable, that is around $100 or less?
    Aug 2004
    This is just a suggestion, obviously depending on your budget and exactly what you need you may way to switch some things.
    http://www.newegg.com/Product/Produc...82E16813135221
    http://www.newegg.com/Product/Produc...82E16819112208
    http://www.newegg.com/Product/Produc...82E16820161615
    Things to look for in a system:
    if your going to be entering standby instead of shutting down make sure the mobo supports s3 standby.
    Instead of looking for a higher end system, try to compromise performance with power consumption.
    Other than that do the normal stuff.
    Read up on the products, check compatability and read reviews for common problems.
    good luck
    REBUILDING!!
    Oct 2006
    Royal Oak, MI
    yeah, i was trying to do the power consumption choices with the mobile amd. this is like an art form picking all this stuff heheh.
    so s3 standby. I always buy all my parts from newegg. what I dont buy from mp3car i will get the rest from newegg. but i dont see, even in the MB you showed s3 standby. So should I pick a few motherboards and go to the manufacturers website to look for s2 standby or is there any easier way?
    I want to make sure its fast enough to run divx movies, play some games, nothing too crazy though, and browse web pages.
    thanks for the help
    I searched on "show off your car" forum with m2atx and i'm looking at what others are running. Trying to get what's most popular and fits with what I need
    Oct 2006
    Royal Oak, MI
    a tad more than I wanted to spend but this combo looks sweet! what do you think?
    AMD Turion 64 Mobile MT37
    http://www.newegg.com/Product/Produc...82E16819103521
    GIGABYTE GA-K8N51GMF Socket 754 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
    http://www.newegg.com/Product/Produc...82E16813128320
    $185.
    $85 more than I wanted, but fast and super low power and runs cool. Might be worth to trade the extra money for headaches.
  1. Build vs Buy...
    By plan_Z in forum General Hardware Discussion
    Last Post: 10-05-2004, 11:45 PM
  2. planning a carputer, input needed!
    By russell1337 in forum Fabrication
    Last Post: 09-21-2004, 11:42 PM
  3. Planning a carputer
    By steve05042 in forum General Hardware Discussion
    Last Post: 07-27-2004, 01:54 PM
  4. Replies: 18
    Last Post: 06-18-2004, 10:11 AM
  5. Replies: 1
    Last Post: 04-17-2004, 04:43 AM
