Results 1 to 9 of 9
Thread: On-Board audio vs. Add in sound card (USB or PCI)
    Newbie JpLelko's Avatar
    Oct 2006
    Elk Grove, CA
    OK i have been researching this topic for a while now. i am trying to decide to either get a MoBo with 6 channel audio on board or a MoBo without onboard audio and use some sort of add it card (USB or PCI). i know that the onboard will most likely use less power, but will it sound as good as an add in sound card. Please let me know what you all think. i would like to use a MoBo with On board audio but not if it sacrifies alot of sound quality. Please leave some comments.
    Thanks ,
    Progress:
    Planning [XXXXXXXXX-] - 90%
    Building [XX--------] - 20%
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    I opted for an onboard and regret it somewhat.
    The sound quality is fine for me.
    I just feel limited in experimenting with better sound cards/ surround formats.
    Jan 2003
    I guess for everyday things and every people...I don't think you would notice. But for audiophile, they only want to best.
    Honestly. I can't tell the difference between my Sound Blaster Audigy and the Realtek Onboard sound. As long as it's clear...I don't really mind.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    It depends on what you are going to be listening to. Just compressed music, you might not notice much, but DVD ands CDs you could probably notice a difference. ALso depends on what you are going to play the music through. What are you using to power your speakers? Are you using a stock oem system?
    Here is a giant list of external soundcards
    Ultimate USB, Firewire, External Soundcard List
    Oct 2006
    Lincoln, NE
    personally, even with my 2.1 setup at my desk at home.
    when i was using my realtek sound, then i had a machine with another onboard chipset (cant remember which) i thought it sounded fine.
    but then i switched to the Audigy 2 and i immediately noticed a significant increase in sound quality.
    ~George~
    1990 BMW 525iA
    CarPC in the works
    Oct 2006
    Elk Grove, CA
    Quote Originally Posted by durwood View Post
    Thank you all for the input. i will probably be mostly listening to MP3s. i had planed on taking the audio out signals and input it into a JL audio amp via mini-jack to RCA cord. then to componet speakers. if you click the link in my signature, it will take you to another thread i started discussing what i have planed out thus far. please feel free to drop in and give some feedback on that too. thanks again to everyone.
    Progress:
    Sep 2006
    Well, if you are using JL amps and component speakers then that means you care about how your music sounds. Go with an upgraded soundcard...PCI or USB version. Your Ears will thank you for it.
    FYI USB soundcards use some CPU resources.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    PCI thanagain, can pick up unwanted noise.... so personally I'd go with a USB-solution.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Oct 2006
    Elk Grove, CA
    Thanks for the input. i think that i will probably revise my plan a bit to change the MoBo for somthing w/o on board 6 channel audio and go with a sound card. another thought is that i want to plan for vista. so i may need a midrange DX10 video card when they come out. food for thought. thanks again for the input and helping me come up with a solution.
    Ciao,
    Progress:
  1. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 06:57 PM
  2. Sound card vs USB card
    By Splinter in forum General Hardware Discussion
    Last Post: 09-06-2005, 11:49 AM
  3. Trust 5.1 External USB Sound Card 510EX, any good?
    By FociMan in forum General Hardware Discussion
    Last Post: 06-26-2005, 06:16 PM
  4. PCI or USB notebook PC card adapter exist?
    By kandyman676 in forum General Hardware Discussion
    Last Post: 01-22-2005, 12:57 AM
  5. FS M-audio Sonica Theater 7.1 surround USB sound card
    By jusatry in forum Classified Archive
    Last Post: 04-19-2004, 09:41 PM
