Results 11 to 20 of 22
Thread: Please check my diagram, fuse size and wire size.
  1. #11
    Newbie BarinaHum's Avatar
    Oct 2006
    Sydney
    My updated diagram.
    Thanks Red GTi VR6,
    I will go with you and DarquePervert recommended to powering my Liliput.
    I'm still not quiet understand many things, being new to the car audio and the car electrical thing.
    Here is my updated daigram, it might help some other newbies out there.
    Car: Holden Barina 98
    Planning: [========80%]
    PC Parts: [==========100%]
    Fabrication: [=====50%]
    Total Progress [======60%}
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    are those USB hubs pulling power from anywhere or are they relying on the single USB line to provide power for everything?
    Jan Bennett
  3. #13
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I didn't power my Liliput directly off my PSU because I didn't want to load down the power supply. Instead I used the egg shaped regulator however I used the PSU to trigger a relay to turn power on and off to the egg shaped invertor.
    This way, my montior turns on and off with the computer, not just the car, but is not directly powered by the PSU. Just another way to do it.
    Added: Nice diagrams. good work.
  4. #14
    Oct 2006
    Sydney
    Quote Originally Posted by RedGTiVR6 View Post
    They are relying on the two USB from motherboard. I already have two USB hubs which don't need PSU to power them lying around. So I was thinking of using them. Do you think I should get one of thoes that need PSU?
    Thank you.
  5. #15
    Oct 2006
    Sydney
    Thumbs up
    Quote Originally Posted by durwood View Post
    Thanks for sharing your method. This could be useful info for me and other newbies. I still don't know much about relay, but it is very useful indeed.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    you can give them a go, but I'd keep it in the back of your mind if you start to run into problems.
    Just because a USB hub doesn't have external power doesn't mean it can power everything you plug into it.
    Only so much current is carried on a single USB line.
    If you plug one thing into that hub that requires all of the current that a single USB line can provide, then what happens when you plug the next piece in that needs just a little power?
    That's where the powered USB hubs come into play.
    Electricity isn't some magically generated thing, you have to provide it when it's needed otherwise things won't work correctly.
    Most of the items you have listed don't appear to be very power hungry, and if they are they will probably have their own power adapter (USB sound card and DVD burner for examples).
    Just keep it in mind if you start to run into issues with things not working.
    Jan Bennett
  7. #17
    Sep 2006
    Here you go..I modified this picture taken from www.the12volt.com
    This is how I have mine wired up just from reference.
  8. #18
    Oct 2006
    Sydney
    Thank you , I certainly learn alot from this forum.
  9. #19
    Oct 2006
    Sydney
    Thank you once again.
  10. #20
    Constant Bitrate popi79's Avatar
    Sep 2006
    remember use a diode
    remember use a diode///
    If you power a relay from your psu remember to use a diode between leads 85 and 86
    85 being the striped side (+) and 86 ground, so when the relay shuts down wont hurt your psu electronics.
    You see, because the relay is a coil it will save some energy in itself and then it will reverse when shut off, this energy can reach up to 200v and a diode will prevent energy from returning to its source.
    "Most of the users you'll see in this site are still learning specially me"
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Wire Size?
    By kbkid in forum Newbie
    Last Post: 12-13-2005, 02:04 AM
  3. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
  4. opus 90 watt, wire + fuse questions
    By studmonk3y in forum Power Supplies
    Last Post: 02-26-2004, 09:55 AM
  5. Replies: 5
    Last Post: 01-08-2004, 12:38 AM
