that makes more sense
Now, you might want to list what year civic. I'm not sure if honda uses Canbus or not. I'm not sure about Honda wiring at all for that matter, as I drive strictly domestics. So wiring up the lilli to the stock speakers could be as easy as going to a local stereo shop or walmart and buying a standard converter kit and wiring it up, or much more complicated than that.
To answer some of your questions
your adding a sub later question, you'll need a preamp out for that. which the PC is. Or you could low level line convert your then existing rears, as I dont think that lilli unit has preamp out, only amped out IIRC.
You are going to want to hook up via VGA. Dont go RCA. the resolution will be too low.
read more. lots more. search on your car. see how others have hooked theirs up. that should answer your wiring question as well as others.
But a quick setup knowing now what you have would look something like:
Code:
Battery
V
14avg wire and fuse
V
carputer-----vga cable and 1/8" to RCA sound cable---->lilliput--wires---->honda kit--->stock wire harness to speakers
^ ^----------usb------------------------------------------|
accessory on wire
