well im starting to get everything I need for my ca pc project, but have a question on how to hook up the sound from the pc....
k, I wanted to know if I could use my headunit that I have now, because it has an aux in-put which is a dolby suround pro logic 2... What would I need to do this? just Y-RCA's?
Car: Holden Barina 98
Planning: [========80%]
PC Parts: [==========100%]
Fabrication: [=====50%]
Total Progress [======60%}
YOu know... There's a FAQ Emporium subforum with write-ups about al these basic questions.
You really should go do some readng there.
FAQ Emporium: http://www.mp3car.com/vbulletin/the-faq-emporium/
kool, thanks... :-) yea I checked the FAQ first but couldnt find what it... thanks
You can use the line out from a sound card. It works, but you run the risk of a loud "thump" when the system turns on. My friend has his setup this way, and doesnt get a thump tho.
On my setup, Im using a USB DAC (digital audio converter), which does not kick in until windows starts, so there is no thump. It also puts out a pretty good voltage to the sound quality is very good.
PhilMayfield - thanks, ill try the convert, but im gonna try just useing the line out hope fully there is no thump.... also, does your friend control the volume through his headunit?
You will almost certainly need a ground loop breaker - they take 2 RCAs in and 2 RCAs out and it will clean up the hum caused by dissimilar grounds. Most car radio stores sell them - between $10 and $30.
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
1.9in x 2.9in -- 47mm x 73mm
