Results 1 to 3 of 3
Thread: my general question regarding the carputer setup
    Dec 2006
    prior to register to the forum I've read many many posts and was amazed many member's work!!! I am really interested in this carputer setup and thinking about setting up one myself. I've built many computers myself but not so experienced in hooking it with other car components.
    I have some questions and hoping some one can verify/answer for me:
    1. Do most of you even boot up the system during the short drives? (getting grocery, etc)
    2. To increase the boot time, most choose to to standby or hibernate. Do you have to do this everytime (even to shutdown) manually after you shut off the car?
    3. How do those OEM devices achieve the instant on upon turning the key to "Acc" power and just take the key out to safely shut off the device?
    Feb 2006
    Vancouver, BC
    #1. Many people have an override switch for their ACC. So on short drives, they switch it off so when you start the car, your startup/shutdown controller or computer never gets the response that the car is on.
    #2 Standby/hibernate DECREASES boot times. Again, a lot of people use a startup/shutdown controller which dictates what happens when the engine turns off.
    #3 Their carputers are very much slimmed down in terms of computing capacity. It's just like if you have an aftermarket HU. The functions are readily available because it's only starting certain things. Many people have acheived fast boot times by slimming down what is starting and what takes priority.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by silvscorp View Post
    Yes, boot times can be tweaked to be short.
    propritary hardware an software
    welcome to the forums!
    btw - I don't use hibernate or stand-by. I shut down completely.
    Jan Bennett
  1. General q's, setup, subs, mobo.
    By TheNewJimJones in forum General Hardware Discussion
    Last Post: 10-05-2005, 08:16 AM
  2. Carputer setup for 2001+ Civic
    By fventura03 in forum Classified Archive
    Last Post: 09-29-2005, 07:35 PM
  3. Using power inverter for carputer - question
    By barnerc34 in forum Power Supplies
    Last Post: 12-31-2004, 05:47 AM
  4. carputer setup: rate my setup
    By Rykielz in forum Newbie
    Last Post: 08-12-2004, 02:44 PM
  5. Replies: 3
    Last Post: 01-05-2004, 10:18 AM
