The motherboard inside a laptop and a PC are very... very different - well physically. You're better off:
1) Keep the laptop and rig it to your car somehow.
2) Sell the laptop and use the $$ to get real PC components.
Hello, I just have couple of questions that I couldn't find...my sister got a new laptop, so I'm planning on using her old laptop to build mine. Is this ok? This laptop is Compaq laptop. I know it's not the Mini-atx motherboard...or i think (i didn't open it up yet) but just wondering if I could just get rid of the keyboard, and just use the motherboard/cpu, and other parts to get the same results...and would I have a problem with power supply if i just buy DC DC power supply and slap it on?
I am planning to do mine with a laptop, I think it should be easier, plus you should have less power consumption, and a battery that will help with shutdown after the car has been turned off. I think though, that you need a laptop with a few things to really get going. USB2 is the most important. Everything you want to add can pretty much be done through USB2.
This thread shows an auto on module: This is how I plan to go.
Laptop Auto Power-On / Turn-On Module
You might as well leave the laptop together. Then if you want a separate KB or monitor, plug them in. IF you need to do work on it, or make some updates, take it inside and do it in comfort.
