Results 1 to 10 of 13
Thread: Dilemma about system specs...
    Nov 2005
    Hi, after about two years of reading up and drooling over people's setups i finally took the effort to put together my sytem but i'm having problem powering the system since the spare mobo and psu i have are pretty power hungry... I've spent 2 year pleading and begging to be allowed to put a carpc into my car and have finally got the permission to do it... I am on a limited budget and i know CHEAP and CARPC are two words that don;t go together but after spending so much on my car i would like to save as much as i can...
    Here is what parts i have laying around for use...
    1. Intel Motherboard integrated Video with a Pentium 4 2.6ghz- a little crazy i know...
    2. Indash Non-Motorized 7" vga touchscreen...
    3. Pioneer DEH-7800MP with Aux input for audio...
    4. 1GB PC-3200 ram
    5. 100GB Western Digital Drive
    6. 1GB Compact flash
    7. PCI Dlink WiFi Card
    8. USB Bluetooth
    9. Bluetooth GPS
    I don't know what to use to power the thing I was planning on using a M2-ATX but many people have said that would be impossible since the P4 requires a ton of power... I think i might have another older P4 under 2.0ghz or an old celeron or athlon setup laying around somewhere... but those im not sure if i still got it or if they are still working...Someone suggested using a shutdown controller + inverter but i heard thats a horrible way to power the system...
    so what do you guys think should i look for another system and get the m2atx or should i go the inverter route???
    Mar 2006
    Colorado, but Canadian!
    you will definately need either an Opus 250 or a DSATX to power the P4. Not cheap solutions.
    So you must way it this way:
    Free P4 + $200 PSU = Cost of $200
    EPIA Board $125 + $80 PSU = Cost of $205.
    Either way, that is the simplest way of putting it.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2005
    what about an old 1.6ghz athlon ??? would an m2-atx be able to power that???
    Mar 2006
    Maybe. Check a power supply calculator. Also it all depends what you will be running with it.
    Is that 100Gb drive a 2.5" or 3.5"?
    How many PCI cards total?
    Check the FAQ for a few power supply calculators, and a guide. Or just google.
    Nov 2005
    I don;t have the athlon cpu and board with me right now so i'm not even sure it even has an onboard video card so i have to assume atleast 1 agp slot... I would like to use a pci wifi card but i also have a wifi usb stick if needed...
    The harddrive is a 3.5" but i am thinking of using the CF card as my main drive so it will be more stable on bumpy roads... i just gotta go see if the local store still has the cf to ide adapters for cheap.
    Elsewhere
    Actually, the P4 2.6 draws 70w or so.
    There is enough power for what you list, but it's definitely pushing the envelope of the M2.
    Don't bother looking for the 2.0Ghz P4, as it suchs about 20% more power than the 2.6Ghz model.
    Your CPU/mobo/PSU choice is OK. I'd check the power draw of all your other proposed hardware to make certain you're not pushing the M2 too far.
    If it doesnt' work out, the DSATX is an awesome unit.
    How about the Wiki?
    Nov 2005
    only 70w? hmmm the athlon draws about either 57w or 66w according to the power calculator so i guess i;ll be keeping the pentium 4... I guess i won't need to find another graphic card as the mobo has integrated graphics so that'll save me a couple of watts... and i guess i can elimate the dvd drive after i install xp since 99% of the time i won't be watching a movie while driving... i wonder if i can underclock the 2.6 since i read somewhere that it has limited speedstep technology...
    what else can i eleminate that will save me more watts usage...What about powering the touchscreen from the fuse box? Ive got this adapter that lets me tap into the fuse box of my car to give me 12v...ive been using it to power my 8 cold cathodes might be a pain to have to turn it on but if it saves me a few bucks i can learn to live with that... how many watts does the average lcd consume anyways?
    p4 - 89w at full load
    hardrive -25w
    motherboard -25w
    ram -10w
    usb bluetooth -5w
    usb wifi- 5w
    usb touchscreen - 5w
    around 170ish at absolute full load ... does that sound right??? how often does a computer ever reach full load? i mean it;s not like im playing Fear or anythign crazy on my car pc... or am i being too hopefully about the m2-atx powering all this???
    Elsewhere
    How about the Wiki?
    xgc
    xgc is offline
    Aug 2006
    florida
    Hi Tekka, DP is right, you will be fine running that p4. I have two p4's (2.6&2.4) in my vehicles. The 2.4 has a ati 9250 video only because the motherboard has no video support and it was the only video card I had laying around at the time. Both cars have m-2 power supplys.
    Nov 2005
    really thats awesome u got like an AIM sn so i can ask u questions about the m2-atx? i'm really excited since i am ready to order the final pieces of my carpc
  1. My dilemma, please help me decide on a system
    By Will Albers in forum General Hardware Discussion
    Last Post: 09-29-2005, 01:28 PM
  2. Ground noise in system
    By TyBong in forum General MP3Car Discussion
    Last Post: 09-20-2005, 03:13 PM
  3. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  4. where to get specs for ATX system ?
    By felix99 in forum Power Supplies
    Last Post: 02-26-2003, 07:08 PM
  5. Do I have HU or not? -- Factory Audio system
    By helloman in forum General Hardware Discussion
    Last Post: 03-06-2001, 04:11 AM
