That looks correct, the relay is wired corectly as long as the switch will be sending 12v+ My only suggestion is adding a fuse on each 12v+ output side of the distribution block, so that each component is fused seperately. Also make sure the grounds all go together so there is no resistance between them and then all together to a good clean chasis ground. Looks fine otherwise just keep it on the opposite side of the car from your audio/video signal wires
LinkBack URL
About LinkBacks
you already have ground to the battery and so doesn't the cig lighter. just delete the connection between the distro and the cig lighter and you'll be golden
PWR and GNA all-in-on...
