Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Cold Weather may have killed HD
    Newbie Smitty0881's Avatar
    Sep 2006
    Upper Marlboro, Maryland
    I'm running a 120Gig Seagate Laptop HD I bought from newegg.com. Everything was running fine and then this morning it stopped working. I turn on my carpc and I see the system doing the memory check and then screen just stays black. I've checked the IDE cable and even switched them out. When I unhook the HD from the board and turn the PC on it boots up and says something about no HD found so I know the board works. I think my HD my have got messed up by the cold MD weather. Is there anything I can do to fix it or do I just need to start looking for a new HD? Thanks.
    Smitty
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    How cold is it there right now? If it's much below freezing, take the pc inside for a while and see if it'll boot once its warm. Your hdd probably isnt dead, it just doesnt like the cold.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Mar 2006
    Colorado, but Canadian!
    Well last night I saw your state was in the -5F weather colour which is -15C. That is pushing the envelope for some drives. I have gotten mine below -20C, but it is the the cabin too. I don't know where yours is located at, but just let it warm up, and it should boot right up.
    EDIT: Looked at the current weather for Annapolis and it says your close to 15F. That should be ok. Again though just bring it up to room temp and try again.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    my 2.5 inches 40g has problems copying files when temperature reches 5 degrees celcius.. I think minus temperatures would be a problem..
    Sep 2006
    I'm in Maryland and at night time its been getting down to about 10-8 degrees. I'll try bringing the HD in the house and letting it sit in the warm for a few hours and then trying it.
    -Smitty
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    You could always put it in the microwave to warm it up a bit...
    Derek
    PS. I'm just kidding about putting it in the microwave. I take no responsibility if you actually do...
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Mar 2006
    Quote Originally Posted by d_sellers1 View Post
    Derek
    If you do put it in the microwave, take a picture of the sparks! Actually I don't think would harm the drive if it was just a little bit. All metal. YOur microwave would take a beating though, but hte drive should be ok. Maybe some burn marks on the platters, but that is what windows bad sector check is for!
    Sep 2006
    Derek
    Hey I did what you said and it set my kitchen on fire!!! What do I do now?!?!?
    Just kidding But I took the HD out of my car and sat it in the house for about 2-3 hours and tried it again but it didnt work. I think it needs to get a little bit warmer. I'm leaving it in the house all day today and I'll try this afternoon.
    -Smitty
    Jan 2007
    Canada
    Below 0C and hard drives do not mix.. I've had my share of laptop batteries start doing the click of death after forgetting them out in the car all night.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    hmmm, I'm in PA...using a 3.5" HDD, had no problems for 4 years.
    Don't know if it's a "fluid" drive or not though.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. cold weather and my motorized touchscreen.
    By skywise in forum LCD/Display
    Last Post: 12-12-2006, 10:58 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Cold weather (-25c and lower)
    By RussellB in forum Newbie
    Last Post: 08-19-2005, 01:23 PM
  4. Carputer and cold weather... very cold!
    By Topper in forum General MP3Car Discussion
    Last Post: 07-14-2005, 08:41 PM
  5. Anyone else having any issues with Cold weather?
    By bry21317 in forum General Hardware Discussion
    Last Post: 01-25-2005, 10:42 PM
