Results 1 to 4 of 4
Thread: newb LCD question
    newb LCD question
    I'm not very knowledgable when it comes to LCDs, so I figured I'd ask the gurus around here.
    I'm in ths process of designing a 'paddle shift' system for my car (Mazda6), and I noticed that when I have both hands on the wheel (in the 'paddle shift' position), my hands/arms often block the little numerical LCD that shows my gear. Normally this wouldn't be a problem, except that the tranny will automatically gear DOWN when speed/RPMs drop too far. There's been a couple times when I'm coming through a corner thinking I'm in the 4th, and when I drop to 3rd, the tranny beats me to the punch and I hit 2nd gear (and redline ).
    My idea is to fab up a HUD, like that found on the older Grand Prix GTPs to reflect my gear off the windshield.
    My questions is ; How hard would it be to connect a numerical LCD to the existing LCD WITHOUT losing the existing one.
    I don't know what the connections are like, and I've never worked with these before so I don't know if its a simple 'splice' or needs something more complicated.
    This is what the LCD looks like. Just a basic numerical LCD that needs to show 1 - 5.
    I guess the title should be more descriptive, but it won't let me edit :s
    Oct 2004
    NY
    doing it with the display is a possibility, but probably a bit complicated too... I would sugest considering the fact that you really don't need a numerical indication in your periferal anyway to give you gear indication.... I would consider just leds, like a bar graph... getting the signals for this should be a bit easier as the tranny probably has a ground circiut for each gear that could be tapped easily enough...
    Feb 2006
    Vancouver, BC
    also fabbing up a HUD is very difficult due to various reasons. Check out the the NightMax post on HUD.
    Oct 2004
    NY
    hud in a single color & low res is no problem & easy... it's high res color images that are an issue...
  1. LCD Power Question
    By Ramb0_Command0 in forum LCD/Display
    Last Post: 08-18-2006, 02:20 PM
  2. Carputer LCD & Laptop Question
    By zzzBrett in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-25-2006, 03:16 PM
  3. Newb question about power from a Molex
    By dsballer2000 in forum Power Supplies
    Last Post: 06-25-2006, 12:32 AM
  4. newb lcd help
    By nick7461 in forum LCD/Display
    Last Post: 11-15-2005, 07:18 PM
  5. Newb LCD question
    By TiziteLayinLow in forum LCD/Display
    Last Post: 03-04-2004, 06:28 PM
