Another Taurus owner. Welcome. Click the link in my sig to see some of what I had planned for my Taurus (putting everything is a Focus now but still have the Taurus).
Sounds like a good idea. But instead of a calling it a "mount", think more of a "dock". It really only needs three connections to the laptop: power, video and USB. Slide the laptop in and the power and video connections are made along with the USB connection that has your touchscreen, GPS, and whatever else connected to it. So think about incorporating a USB hub in to your dock. Consider a USB soundcard so your audio connections will remain plugged in to the USB. This will also allow you to utilize 4.1 sound instead of stereo which only consists of right/left audio. Speaking of audio, you will be needing an amp to drive your speakers if you remove the stock head unit. You just need a small four channel amp. Nothing very big or special is needed.What I want to do is fabricate a "mount" for my laptop, under the passenger seat using the existing studs and nuts for the seat. The laptop will be mounted on a sliding tray (think keyboard tray on a computer desk) that will be able to be locked in place for driving, but will allow easy access to remove or work on. Since I'm using the laptop, I figured I would just use a inverter to supply the power.
This may or may not work. The easiest thing to do is get a stereo installation kit for the Taurus (it's so you can install an aftermarket stereo). This way you can cut that up and mold your screen in and you won't have to worry about HVAC controls (unless you have digital then forget about it...). Before you buy your screen, ensure that you get the dimensions to see if you will really have room. I was going to use an 8" 4:3 screen and relocate the HVAC controls. The only problem with the is the HVAC controls run off of vacuum lines would not be easy to extend and relocate. I scrubbed that part of the idea and went with an indash screen.I plan on making a custom dash panel and molding a 7" touchscreen into where the factory radio/HVAC would go. The custom dash panel will keep the HVAC controls.
Take a look in the GPS section to get information for that. Personally, I have the older style Delorme Earthmate USB GPS and use the serial drivers so I can use it with iGuidance. Not many people seem to like the Earthmate and I don't know why; it works fine for me. But do your own research to see if there are better/newer ones out there. Since I already have mine, I don't do much looking to see what's new out there. There are also a few AM/FM USB devices out there (which I cannot remember any names for at the moment) that you would want to get in order to be able to listen to AM/FM stations. You can find all that information here on MP3Car.The computer will be used mostly for GPS and audio. I havn't decided what GPS to get yet(opinions welcome)
Now all this is based off what I know of automotive electronics and computers, but what I really need some guidance on, is how to all make this work in the car. I realise that somehow I'm going to have to wire up the screen/computer to the ignition, but I don't know how to do this safely(so i dont damage the computer). Also, since I'm removing the stock radio, I'm wondering if there is anyway to control the AM/FM radio w/ the laptop? I plan on listening to the laptop and MP3's most of the time, but I do enjoy listening to the football game when that time comes around.
This is definitely the place to do your research.I havn't researched too much yet, so I don't know the specifics of this whole project, but from what I have researched and decided upon, I hope all this can work![]()
Derek
LinkBack URL
About LinkBacks
Just need a good place to look up parts to build it, I've searched Newegg breifly but havn't turned up much...
