Results 1 to 8 of 8
Thread: Newbie car battery question
    Feb 2007
    Question Newbie car battery question
    I have a 2005 Hyundai Tucson LX that I'm wanting to add a backup cam & lcd screen to, but I have never installed anything in this car before & am worried about disconnecting the car battery. I'm sure this is probably a stupid question, but will disconnecting the car battery reset the stability control program, shiftronic, or something else that will be a lot harder to reset than the clock & radio presets?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i believe that deppends on the car.. 99% sure it won't affect it.. but in my citroen Xsara, when one day i did that and i had forgotten the key turned (the car was not started - just the next click after accesories) my imobilizer got jammed and i needed to reprogram it... had to take it to Citroen for that..
    just ask your dealer to make sure..
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    you may want to make sure you have the radio security code, just in case i know with holdens you need to reenter it when you remove the battery for a while - my 2 cents.
    Feb 2006
    Vancouver, BC
    read your car manual regarding disconnecting the battery. But I would think something as important as traction control systems wold be hardcoded and would not have to be reset.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Volvos also use a security code on the radio when battery is disconnected. (theft deterrent)
    I agree that the rest of the car shouldn't care.
    Feb 2007
    stability control will auto restart once you hook up battery. as will everything else. it may have to relearn a few things but the car will be fine. now that stereo. I would make damn shure you know the code first.
    Newbie STILL_LUKING's Avatar
    Jan 2007
    Coastal Paradise
    Quote Originally Posted by Nomader View Post
    ha ha .. you should have known better than that. NEVER ever keep the key turned on while you remove/refit the battery.
    Aug 2006
    Bendigo/Victoria/Australia
    all cars have to be designed so you can pull the battery out. but their are things you need to be aware of
    make sure you have your radio code
    always have the key in the off position on your ignition
    Never reconnect you battery untill you have finished working on your car.
    the reason for the third one is some cars like mine, check to see if your airbag has been fidled with and the cars computer needs to get cleared.
    Everything else will be fine, it's all hardcoded or recalibrated on reconnection
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 09:52 PM
  3. Custom ignition/alarm/immobolizer system
    By PredatorCoder in forum Hardware Development
    Last Post: 04-07-2006, 05:42 PM
  4. Replies: 3
    Last Post: 08-04-2004, 05:52 AM
