Results 1 to 8 of 8
Thread: Is this even possible?
    Newbie hermangarza's Avatar
    Dec 2002
    I know you can plug a cf card to ide with an adapter, but can you got the other way? this board comes with cf connector build in, but i want to plug in a 44 pin hard drive. any ideas?
    thanks
    computer controlled switches?
    Dec 2002
    any one?
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    “Do not speak unless you can improve the silence”
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
    Low Bitrate briderx's Avatar
    Mar 2007
    Tacoma, WA
    I'd say no.. From a quick check on google, it seems like it'd be only the other way around.. I will have to admit, it seems logical that you'd want to do that.. BUT, I don't think there's enough market for any manufacturer to actually produce such an item.
    Dec 2002
    maybe i have to use a pci adapter
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Your mobo doesn't come with an IDE/SATA connector? If you use it as a 2nd drive, USB is another option.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2002
    nope just a cf slot and the rest usb, pci, vga, serial, even dvi
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I would suggest PCI card with an IDE controller.
    TruckinMP3
    Read the FAQ!
