You just want to know how to wire a button and a switch?
You have to be more specific.
You want a button for the on/off button on the PC? THe one that goes to the mobo header?
You want a switch to flip the inverter on and off? That is easy enough. Just get a standard on/off switch. One prong goes to the +12v. The other prong goes to one side of a relay coil. The other side of the relay coil goes to ground. Then the power and ground from inverter to the relay.
LinkBack URL
About LinkBacks
