your limiting factors is space. You should be able to fit a screen in the double din spot. All comes down to which screen you choose. You could fit a computer into the dash if you got the space. Mini-itx boards are only 17 cm by 17cm. YOu should check out the FAQ's to see everything you need and then check out the projects for various examples.
LinkBack URL
About LinkBacks
