If you actually have both copies than always install Pro. The networking advantages are nice. And for file transfering, pro is nicer. I don't know why but the only XP Home computer we have always drops itself and the printer randomly stops sharing and all sorts of stuff. XP Pro, no problems. That is about the only thing that you would use in the CarPC from the Pro advantage.
Onboard sound is just known for its hissy-ness or whining. I have neither problem and if you do there are things to fix it, but if you are an audiophile, a better soundcard will be in your future.
gain != volume
and volume is controlleable PC side.
I want to know what you did with thermal paste!But not really any difference. I always handle the via boards carefully like an egg, because it just looks so meek and fragile. I know it could probably take it, but it was the most expensive motherboard I have purchased and it is the #3 out of now over 11 computers speed wise yet the "newest"!
Capacitor == bandaid
As long as your voltage range is within what the M1 or M2 can handle, and you use nice thick wire, you will have no problems. The power supply is not like a speaker where you can see the power fluctuations such as speaker sounds or dimming lights. With the PSU, it will try its hardest to level out the voltages.
Make sure it is powerful enough for what you want.
If you want what you say here, then this is plenty power. If you want to do video games, then no. SNES emulators are fine, but N64 is probably pushing it because it isn't as efficient.
Also the M2 is more bang for your buck over the M1.
LinkBack URL
About LinkBacks
