Results 1 to 4 of 4
Thread: Amp to Subs turns on and off
    Feb 2007
    i powered my amp up into this new car.. when i put power thru the sub the amp stops sending sound until i lower the volume and then it resumes pushing the sub at the lower volume... anything i can trouble shoot?
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    I got nothing. Possibly some type of overload protection on the amp? Does a red led come on the amp when the audio goes out?
    Maybe some more info. Stock Stereo? what kind of amp. How is everythintg wired? Maybe check your ground connection on the amp. sometimes amps will cut out if there is bad ground.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    probably clipping
    Feb 2007
    its clipping ... i changed out the amp and it all works fine now .. guessing after 6 years the kenwood finally gave out .. no worries
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-07-2003, 11:07 PM
