unless you can get to the bus bar of the fuse block id suggest trying to run some 10ga thru an existing hole in the firewall and fusing a new lead close to the main battery. the space might be tight but try some soapy water and try to slide it thru. this is the best reversable option IMHO second best i think would be to go to autozone get a 1/4 in grommet and drill a whole in the firewall and snake your new set of wires along the nearest wire duct and enclose the new wires in your own wire duct, this makes it professional in that it looks like its OEM unless you have seen 100's of these cars before and notice the extra duct
LinkBack URL
About LinkBacks
