Results 1 to 7 of 7
Thread: TV and stuff in my VW bus
    Mar 2007
    Hey, i'm new here, as you might have guessed. I want to put a tv, dvd player and xbox in my '71 vw bus, but i don't know where to begin. I'd like to know how to integrate it so that the sound comes throught the car's stereo. I also want to make a switch board to easily switch between devices. I have no idea what i need to do this, or where to start. any help would be greatly appreciated.
    _
    Mar 2004
    Little Elm, Texas
    I would really suggest doing a bit of searching as all of the information can be found on this web site.
    There is a how-to on the stereo located in the FAQ emporium as well as an entire sub forum about car audio.
    As for a switch, you probably don't need to MAKE anything since I'm sure a switch board is already made.
    Jan Bennett
    Variable Bitrate quantum's Avatar
    Sep 2005
    Quote Originally Posted by Agent_Orange View Post
    Oh, that would be cool though. I had one of those vans eons ago, and they are just plain fun. Ride like ****, but fun. You could probably put an entire server bank in that thing!
    Mine had this 4 ft long sunroof, with about a 3" handle you had to hand crank to open it. After a few hundred turns and a tube of Ben-Gay for the shoulder, it would open a few inches. Finally got smart and rigged it so I could put my cordless drill on it instead. It was the only VW Bus I knew of with a 'Power Sunroof'
    Anyway, do as Red said and search your heart out, you'll find tons of ideas.
    Good luck!
    Mar 2007
    thanks for the replys, i can tell this site will be an invaluable resource
    If i got an lcd computer monitor, is there a cable i could get to hook an Video jack to it, so it would be like a tv?
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Another thing that you can do is order a mod-chip for your x-box, then you will be able to swap the HD with a bigger one so you can put different emulators and roms on it, pls save your games to the HD, basically set it up like a carpc with some limitations of course...
    Mar 2004
    AO. The first thing you might want to consider is upgrading to an alternator and adding a second battery to your bus. If your planning to use any of these when camping its a defenite must.
    The stock generator in your bus is only 38 amps. And I'm not confusing the terms; its a generator, not an alternator. After the power all the car electronics take, you are not left with many free amps to run your car pc or other toys.
    71 is a good year. Power brakes, screaming dual port motor. Is your bus a Westy?
    Im currently fixing up a 68 Westy Weekender.
    Mar 2009
    VW Bus
    Hey I am currently restoring a 76' weekender bay ad i was wondering if anyone has ever installed an additional alternator perhaps a 250 amp with a deep cycle battery. if anyone has any additional information or advice would be much appreciated.
  1. TV Tuner/FM Tuner
    By tangeray in forum Car Audio
    Last Post: 06-17-2005, 06:16 AM
  2. What TV tuners ?
    By tolisn in forum Road Runner
    Last Post: 03-31-2005, 03:23 PM
  3. ATI TV WONDER™ VE pci more stuff !!!!
    By allenruble in forum Classified Archive
    Last Post: 06-01-2003, 12:07 AM
  4. What TV tuner card are you using to record TV shows?
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-24-2003, 12:44 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
