Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: networked pc's in taxi.
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RedGTiVR6 View Post
    you say you have upgraded the stereo in the car...I'm gathering that you mean you've upgraded the radio. If that's the case, I seriously doubt that it has no RCA outs as nearly every single aftermarket HU out there has RCA outs.
    Can you give me a link to the HU that you purchased?
    It almost sounds like you're trying to go from the speaker output to an amplifier...which will not work.
    NOT .
    It is possible although it may not be a great jump in quality (if at all. and audiophiles hate the idea) it will enable you to get a bigger amp and therefore speakers.
    If you have already upgraded the HU and haven't upgraded the speakers when you did, it might be worth while putting some decent upgraded speakers in first, you never know you might have a decent output from the radio/HU but are being let down by the speakers.
    Anyway post some pic's of this install and more info on the upgraded HU.
    Cheers.
    Quote Originally Posted by 2k1Toaster View Post
    I want to ride in your taxi!
    But have you considered a USB soundcard? Relatively quick and cheap. Dramatic quality improvement for little money.
    eh? No.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Enforcer View Post
    eh? No.
    from the via's onboard, yes there is an improvement! Or no you don't want to ride in the awesome taxi!
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    Using a line level converter is just not a smart idea...no matter if you are an audiophile or not...it's a poor solution to the problem.
    I'd equate it to using sticks to solve a higher math problem...it's a super poor way to find the solution to the problem.
    Jan Bennett
  4. #14
    Nov 2005
    UK
    it say it's about equivilent to an fm modulator
  5. #15
    Newbie DigitalDub's Avatar
    May 2006
    Berkshire, UK
    Quote Originally Posted by taximark View Post
    The factory stereo has already been upgraded. it doesn't have rca (phono) outputs but the pins are there on the iso connector I think. If not i think you can get amps that use speaker level inputs
    Well, when I bought my van, it came with an old headunit connected to an amp by the speaker lines. There were a couple of widgets in between the head unit and amp that appear adjust the line levels. The widgets had pots that you use to adjust the output to the amp. Buggered if I can remember what the widgets are called. I think they sell them in Maplin though.
    Now I just run the carpc straight to the amp.
    I live just down the road in Reading. Reckon the other half would love your cab, being a fan of Lucky Voice.
    Edit:
    That's the chap. Seems not a good idea though. When you're in a noisy '68 van though, good sound quality is somewhat wasted anyway...
    D.
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No, I'd equate it to using an inverter to supply power for a carPC.
    ops that's what I'm still doing at the moment.
    Note to self : must get those PC's changed over.
    both
  7. #17
    Mar 2007
    Wokingham, Berks, UK
    i also have a 1kw invertor. just run the smoke machine off that tho.
  8. #18
  9. #19
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Welcome to the taxi driver/pc operator for fun & profit club, Mark. Afraid I beat ya to the punch by a bit tho. Best of luck.
  1. Ultra mobile PCs?
    By wayland1985 in forum Newbie
    Last Post: 01-14-2007, 01:44 AM
  2. FS: 2 LCD Monitors, 2 PC's
    By fventura03 in forum Classified Archive
    Last Post: 10-18-2005, 07:32 PM
  3. HP Embedded Thin PCs.....
    By camsgs3 in forum General Hardware Discussion
    Last Post: 03-31-2005, 02:06 AM
  4. Confused about shuttle PCs vs via processors
    By clean customs in forum Newbie
    Last Post: 03-04-2005, 10:13 AM
