Results 1 to 10 of 15
Thread: Buy Pre-Built or Not
    Mar 2007
    Hey guys, been lurking for quite a long time so i think i have enough knowledge to start building (read: buying) my first system.
    So far i have decided on this from the mp3car store:
    Code:
    # Via Motherboard:Epia SP13000
    # DDR Memory:512MB Full DIMM PC3200 RAM
    # Hard Drive:40GB 2.5" 5400RPM HD
    # Vehicle Power Supply:M2-ATX 160W DC-DC
    # Operating System:None
    # Monitor:Xenarc 700IDT In-dash Single Din Touchscreen Monitor
    # CD/DVD Drive:Panasonic Slot Load DVD-ROM/CD-RW Combo Drive
    # WiFi Adapters:None
    # Bluetooth:None
    # Sound:Advantage Roadie 7.1 USB Externall Surround Sound
    # Keyboard:None
    # Build:Customer Build
    I will be using tinyxp and frodoplayer and also adding a gps reciever later on.
    Now question time.
    How does that system look? Will the M2-ATX be able to handle all that? I did some quick calculating and it looks like it should manage, but i couldn't find exact power numbers for everything so i'm not 100% sure.
    Second question, if i buy the system as a pre-built system, then it will cost $1,145. But because alot of items have discounted prices, if i buy all the above items seperate (from mp3car shop), it is only going to cost $930.
    Is anything included in the pre-built systems that i wouldn't get from buying the items seperate? If it's only random cables and stuff then i can pick that up myself. It also means i can buy everything else and put it all together while i'm waiting for the Xenarc to be restocked.
    Sorry if the questions sound a little stupid but i always like to be 100% sure about something before i go handing this kind of money over.
    Elsewhere
    The M2ATX should handle all that with no problems whatsoever.
    And no, there's nothing that the pre-built system has that you wouldn't get if you ordered individual parts and built it yourself.
    How about the Wiki?
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    but, it might be cheaper to build it yerself, a nicer hard drive (that one is small and SLOWWWWWWW) and i dont really like those flimsy indash motorized LCDs
    they usually arent as good quality (prone to motors dying, the screen breaking off, etc etc etc) and also many of them have lower contrast and view angles than non-motorized lcds
    also, competely personal opinions, DD screens look cooler than indash single din
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    FLAC J187's Avatar
    Nov 2004
    Boston
    There are two types of car computer users IMO. Those who want to HAVE a car computer and those who want to build one. If the thought of building a car pc doesn't give you some excitment, you may want to buy. I personally would rather build then buy even if buying saved me $200.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    J187 has hit the nail on the head.
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by Redian View Post
    Redian, I was just about to purchase that same exact hard drive. Which HD do you suggest?
    EDIT: Never mind i checked your CarPC Spec.
    If you cant DODGE em, RAM em.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by MrJamieR View Post
    Quote Originally Posted by Ramanator View Post
    A HD with 7200rpm and a large (8mb or more) cache.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Quote Originally Posted by J187 View Post
    I do actually find more appeal in the build. The only reason i was going to buy it prebuilt was because i didn't trust myself to remember all the components. But since it will end up the same it gives me some flexibility about what components i decide to buy.
    Quote Originally Posted by 2k1Toaster View Post
    Will do.
    I thought the 700idt was spring loaded. I was wanting an indash screen because it looks more stealth and is less likely to get stolen. I'm also quite useless at fabrication.
    If the screen breaks off the 700idt i guess i can always just go the DD route.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by D3LTR33 View Post
    Ok, well you don't have to trust yourself, there are tens of thousands of posts here to remind you.
    Besides, if you forget something then it really only costs you a little extra shipping and some time to get it. Building will give you more flexability, better upgradability, a better understanding of to operate and fix the unit and most of all, a sense of accomplishment that, for me, rivals the thrill of using the thing.....Imagine if the Egyptions built the pyramids, then stepped back, and got GPS on those bad boys....C'mon, you gotta build it
    Please help.
  1. Drivesoft Buy or Build
    By wantone2 in forum Newbie
    Last Post: 09-23-2005, 02:30 PM
  2. Rikaline 6010 - where to buy in Greece?
    By Johnnie in forum GPS
    Last Post: 12-09-2004, 06:07 AM
  3. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
  4. were 2 buy aInfrared receiver under $20?
    By babas151 in forum General Hardware Discussion
    Last Post: 08-23-2002, 03:18 AM
  5. Where to buy seiko L4034
    By Adam F in forum LCD/Display
    Last Post: 12-27-2001, 12:21 AM
