Results 1 to 10 of 10
Thread: How to mount carpc box
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    I have a microatx CarPC in my trunk and I'm trying to figure out the best way to install it permanently.
    I have dual 12" subs, 2x200 watts in my trunk. I like to turn it up. This won't change. My hard drive just died (Maxtor 3.5 80 gig). It worked fine until (my theory) my pc case got pushed up against my sub box (contents shifted during flight). I have a temporary, smaller 3.5" hard drive in there now so I have tunes, and have made an effort to keep the pc and sub box separated.
    My question is -- is it better to hard-mount the CarPC box to the car (like screwed in) or have it just kinda strapped in? Where is a good place to mount the hard drive? I've seen that some people fabricate a mount under the rear deck -- is that recognized as a location with less vibration? Or should I do the USB enclosure under my seat thing?
    I plan on getting either a laptop hard drive or CF as my boot disk, and then having a larger 3.5" drive for media storage. Any thoughts?
    Feb 2006
    My personal opinion is to try and get it separated from your subs. Plenty of people have thier PC mounted on or near their subs but hard drives are not made to withstand vibrations. Shocks they handle fairly well, vibrations they dont. I would hard mount it to the car in whatever spot you can that has the least vibration from your subs.
    Constant Bitrate symon_say's Avatar
    Aug 2006
    Dominican Republic
    Try using some sound deadner around the case to reduce vibration, but be sure your case is well ventilated cause sound deads are heat proof to.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Make sure you have good air flow and mount the case firmly to the car. Do not worry about the rest.
    TruckinMP3
    Read the FAQ!
    Mar 2007
    This might be obvious but it needs saying
    I'm a newbie myself, but I do know a bit about computers and sound. This is going to sound really dumb, but here goes.
    Isn't a speaker just a big magnet? I would have thought that, unless you have some kind of shielding you need to keep your hard drive as far away from that magnetic field as possible.
    Nov 2006
    Everett, WA
    Okay that sounds reasonable. I'm mostly concerned about whether I should keep the hard drive in the case (in the trunk) or relocate it to the passenger compartment.
    Mar 2007
    Quote Originally Posted by crooper View Post
    Personally, as long as you can hide it to a certain extent, I'd stick it in the passenger compartment, makes wiring easier for one thing!
    FLAC J187's Avatar
    Nov 2004
    Boston
    If you think there are enough vibrations to really cause a problem, you could install the HDD in a verticle position which will prevent the platters from hitting. I always had mine vertical, but it was for installion ease. Horizontal should be fine too for most, but verticle will still offer some amount of benefit even though today's drives are much more durable than even a year ago.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    I think a good place to start would be some duct tape. That way you can a least secure your CarPC long enough for you to look at more permanent options without loosing another Hard drive.
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by TruckinMP3 View Post
    As for HD/PC mount, do .
    If there is space in the cabin, install your PC there. Why? it will share the heat and AC with the occupants.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Starting Fiberglass sub box!
    By pcmofo in forum Fabrication
    Last Post: 09-07-2009, 12:47 AM
  2. Connecting CarPC to the Speakers
    By Matthew230 in forum Car Audio
    Last Post: 05-27-2008, 05:28 AM
  3. CarPC with Pocket PC (Axim X30)?
    By UTChris in forum General Hardware Discussion
    Last Post: 01-29-2008, 02:44 PM
  4. Powering carpc and amp
    By bjfrank in forum Car Audio
    Last Post: 04-11-2006, 02:32 AM
  5. carPC newb, seeking advice
    By inaneninja in forum Newbie
    Last Post: 01-25-2004, 10:17 PM
