Results 1 to 4 of 4
Thread: digital dash question
    Mar 2007
    hi everybody, im a newbie. anyway my question is, i have an 89 ford probe lx with a analog guage dash and i wanted to put in a digital dash from another probe of the same year, is it a simple swap or do i need to change the wiring connector to fit the digital dash, can anyone tell me what needs to be done to do this swap.
    Oct 2006
    Las Vegas
    No promises, but I might be able to help if you can tell me what model the donor car and your car is: GL,GT, or LX.
    Edit: After researching this, the answer is no, not without marjor parts swapping, at least other harness and connectors. The connectors are different and the pinouts are not even kind of close. PM me for a diagram if you like.
    It's been a while...
    Mar 2007
    ok thanks, ill have to see if i can get the harness and connectors and try to make it work
    Oct 2006
    Las Vegas
    There may be more to it than that, the sensors (oil,etc) may be different. The best way to check is to take the diagram I have waiting for you, and look up each component that is connected in the circuit at a parts store (rockauto.com works well) and see if different components are listed for digital dash vs. analog. This could get expensive. I would spend much time planning this before going to gather parts. But, that's how I do everything.
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. Using Digital Mods while driving (IsSafe) question
    By Aquaman in forum DigitalMods (Scripts / API)
    Last Post: 01-31-2007, 02:38 PM
  3. Accord lcd question - placing lcd deeper in dash
    By mykolJay in forum Fabrication
    Last Post: 09-29-2004, 02:02 PM
  4. Question about the dash mount
    By mikelee516 in forum Classified Archive
    Last Post: 10-24-2002, 03:56 PM
