Results 1 to 7 of 7
Thread: CarPC install on 96 Jeep Cherokee - Questions..
    Low Bitrate briderx's Avatar
    Mar 2007
    Tacoma, WA
    Okay, I know lots of people don't recommend installing a CarPC under the driver/passenger seats.. So, I devised a plan.. How about putting it in the center console? I was planning on doing this, using 1" risers (aluminum) to bolt the mainboard down to (no case). Build a custom lock box with air vents..
    The items I SHOULD need are:
    Mainboard/Proc
    Ram
    Hard Drive (already have 2.5" 20gb)
    Monitor (7" Touch Screen - In-Dash)
    Some sort of inverter??? (Suggestions????)
    and the "Picto-PSU" or whatever that's called..
    Is there anything I'm missing?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by briderx View Post
    Mainboard/Proc
    Ram
    Have you figure out why carPC under driver/passenger seats isn't an idea? If there is space for it why NOT? And I am sure you have plenty of space on the passenger side on the Jeep.
    Said NO to the following "Pico PSU". For PSU, either DSATX, Opus, M1/M2-ATX. Inverter + Home PSU is okay if you don't have the cash, but not recommended.
    BTW
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2007
    Tacoma, WA
    Thanks for the response.. I personally don't want one under there, specifically for this reason: Water.. I have had standing water in my jeep before (going through rivers/such..) PLUS, if I create some sort of box inside my center console, I won't have to fork over another $100+ for a case.
    This may be a dumb question.. As I would NEVER use a home PSU in my car.. BUT, will I still need an inverter if I buy a DSATX or one of the others recommended? It seems like I wouldn't...
    _
    Mar 2004
    Little Elm, Texas
    Installing under the seat isn't a good idea in most any install so don't feel bad about your situation.
    No - you just need the DSATX, that's it. It IS your PSU.
    Jan Bennett
    Mar 2007
    Tacoma, WA
    Quote Originally Posted by RedGTiVR6 View Post
    NICE! So.. Looks like total (w/o monitor) will run me around 350.. That's just the beginning! Dance!
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    I had a 91 Eagle talon tsi, the pc fit perfectly in the middle console (with a lot of cutting) I just used the console as the case... I also used a 400W home powersupply with a 500W inverter and it all fit in there as well, of course that was before they came out with the M2
    Apr 2006
    If you search, I don't remember who, but search Jeep Grand Cherokee and it'll show you that at least two, possibly more, have installed in the center console. Mine is installed where the cd changer would go.
  1. 2001 Jeep Cherokee Limited
    By shakes in forum Show off your project
    Last Post: 04-19-2011, 04:15 PM
  2. Mazda3 carpc install
    By scote in forum Show off your project
    Last Post: 01-10-2007, 09:22 PM
  3. 2000 Jeep Cherokee carputer install - worklog
    By akula169 in forum Show off your project
    Last Post: 12-13-2006, 02:33 PM
  4. NewB Questions for Laptop Install
    By PaulDePimp in forum Newbie
    Last Post: 02-09-2004, 11:57 PM
  5. 1997 Jeep Cherokee - Custom In Dash
    By SeeBQ in forum Show off your project
    Last Post: 11-13-2003, 04:11 PM
