THe stock wiring is not sufficient for any power draw really. Just run a dedicated wire, and you will be happy. The stock wiring may be able to handle it, but why play roulette with your car?
And to power the lilli off the M1 then you need to chop off the "egg" (unregulated car voltage to stable 12v converter) and you can use the yellow and black wires from the power supply.
Or you can probably wire the screen with the egg to the stock power wire.
You can get the ignition wire from the stock harness though because it is just a remote signal.
LinkBack URL
About LinkBacks
