Results 1 to 7 of 7
Thread: M1-atx keeps rebooting pc
    Jan 2006
    Ireland
    Ok lads done alot of searching on the forum but I can't see anything relating to my problemMy M1-ATX power supply arrived today and i set about wiring it.I'am powering it from an old atx power supply which is still hooked up to an old pc.I have the earth connected to the earth on the molex connector and the live to the live and then to switch the pc on i connect the switched wire to the live...no problems yet if your following me.Then to swithch it off I disconnect the switched from the live and it shuts down BUT THEN RE-BOOTS STRAIGHT AWAY.
    Is there a problem with the way I have it hooked up or what and would it be different when installed in the car????
    I'am installing the pc in the car at the weekend and don't want to have this problem then.
    Help please.
    Low Bitrate dontpntpool's Avatar
    Aug 2006
    IA
    PUNCTUATION!!!
    I cant really read what you typed so I will just say that I think that maybe you should really try disconnecting everything first then try booting it might be to much power but I am not sure if there is a problem or your just hooking it up wrong so the switched power isnt really off or live
    Jan 2006
    Ireland
    Quote Originally Posted by dontpntpool View Post
    PUNCTUATION!!!
    Sorry you can't understand.I'll try again.
    The system boots up fine but when I shut it down it restarts itself.
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Do you have S6 (I think it is) hooked to up to the switch header on the PC?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
    Jan 2006
    Ireland
    Quote Originally Posted by walstib View Post
    Ya I've got it hooked up.
    I have no problems when I use it as a normal psu with no jumper,it powers up and down.When I connect a jumper it shuts down and reboots.
    Jul 2005
    Atlanta, GA
    Are you sure it's hooked up to the power switch pins and not the reset pins?
    Jan 2006
    Ireland
    It's hooked up to the right pins.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. M1 atx remote lead
    By boomintrac in forum Power Supplies
    Last Post: 02-28-2006, 09:29 AM
  3. m1 atx is killing my battery on taxi mode
    By cass944 in forum Power Supplies
    Last Post: 11-23-2005, 10:54 AM
  4. M1 ATX, hangs. Help a swede in need.
    By Biograph1001 in forum Power Supplies
    Last Post: 11-18-2005, 10:01 PM
  5. Old atx pc
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 02-04-2002, 10:30 AM
