Results 1 to 2 of 2
Thread: problem with map monkey and gps antenna
    Nov 2006
    hello guys i have a problem with my gps antenna.
    the antenna is a haicom hi-204E usb.
    i had some problems installing it and making it work but anyway i made it work.
    haicom has a program tha tests the antenna and you can see how many satelites are connected.
    everything is good until i run map monkey.
    the gps is in com4.
    when i select find gps in map monkey it says gps found but the only port i can select is port3.
    and of course the gps doesnt work.
    (it also sais that the com is busy and i f i try different settings to make it work then it crashes and needs re install)
    in fact if i press ok it says low signal and it doesnt show me the right posittion. (where i am)
    any ideas why i cant select in map monkey the com4 for the gps?
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by jimacid View Post
    the gps is in com4.
    try forcing the com port of the gps to a different no ie com1/2/3
    goto device manager, 'ports' and select your gps, then goto 'advanced' and change the port from there
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  1. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  2. Problem with ME and Map Monkey
    By DCS in forum Media Engine
    Last Post: 10-31-2007, 05:20 AM
  3. problem with gps mouse ad map monkey
    By pijo1971 in forum GPS
    Last Post: 10-14-2005, 02:24 AM
  4. Replies: 3
    Last Post: 03-31-2005, 07:17 AM
  5. Anyone using Map Monkey 1.1.3 with Deluo USB GPS?
    By Chita79 in forum Map Monkey
    Last Post: 02-04-2005, 02:06 AM
