Results 1 to 4 of 4
Thread: New Lilliput Monitor - Help??
    Low Bitrate briderx's Avatar
    Mar 2007
    Tacoma, WA
    I am having issues with my monitor.. I found this FAQ that might help most of you that have been looking at this thread. I am gonna be following it to a T! If you have any questions, check here first!
    http://www.mp3car.com/vbulletin/lcd-...-lilliput.html
    Thank you to hevnsnt for this!
    BTW: I am not claiming ownership to this FAQ, I am just relaying info for anyone that's having problems with theirs as well!
    Aug 2005
    Pennsylvania
    Have you tried a different resoulution such as 640x480 or 800x600?
    Mar 2007
    Tacoma, WA
    Yeah, tried basically everything up to 1600x1200 (just to make sure).. The monitor connects great with the computer.. You can hear it connect.. (on the computer side (device connection)).. But what scares me, is that when I change from PC to like Vid 1 or Vid 2, it won't show any text in the top right corner.. So, leading me to believe that the light is bad?
    Mar 2007
    Tacoma, WA
    What I ended up doing is realizing that it's basically stuck in standby mode and would not go into normal mode. I COULD have taken it apart and maybe fixed the issue. I am getting a replacement instead. Hope this helps someone in the future!
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  3. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
