Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Build on Linux
  1. #11
    May 2009
    Oh, excellent! A built package of OSX is helpful right now. Eventually I want to use my Linux laptop, but right now I want to set it up on my Mac laptop. Thanks for that.
    So I actually need to ask a preliminary question not at all related to your software. I bought the same G-Sat GPS receiver you have, and I have a Mac like you must have. I open Bluetooth Preference Pane and add my device there. But when I'm done with the little configuration wizard, the GPS device shows up in the list, but the little icon is red and it says Not Connected. Is there something I'm missing about how to get the these two devices to connect to one another?
  2. #12
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    The mac will magically make the connection for you as soon as you try to actually *use* it. ie, just try launching gpsd -Nn /dev/cu.{whatever it is}. You don't need to "connect" to it first.
    I was experimenting again with linux bluetooth last night, and while it was pretty doable, there were still the odd difficulty [such as ubuntu 8.10 not actually making a connection if I went through the GUI]. I'll gladly provide some help when you get to that stage, too :-)
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  3. #13
    May 2009
    Right you are, thanks, as soon as I ran gpsd (which on my Mac is gpsdX -- is that the same for you?) the G-Sat started blinking blue once per second, which is its signal for being connected, and the Bluetooth Prefs Pane showed it as connected. Wonderful.
    Then I started up obdgpslogger
    Code:
    ./obdgpslogger -s /dev/cu.BT-GPS-37C5BE-BT-GPSCOM-1
    and I got this
    Code:
    Opening serial port /dev/cu.BT-GPS-37C5BE-BT-GPSCOM-1, this can take a while
    Successfully connected to serial port. Will log obd data
    Successfully connected to gpsd. Will log gps data
    Didn't get parsable data back for cmd 05: 25,17,168,,21,15,109,,09,06,058,,07,04,320,*7B
    $GPRMC,161420.760,V,,,,,,,220509,,*22
    And a bunch more $GPRMC lines after that. I get more of those $GPRMC lines every few seconds, always preceded by the line saying it didn't get parsable data back for cmd 05. Does that refer to the OBD dongle? That's my guess because I am in fact in my living room, not sitting in my Jeep with the dongle.
    So that's all pretty good. I was doing that on my Mac from a Terminal inside your OSX package (in /Content/Resources/bin). Next thing I'll try to do is to sit in range of my OBD dongle, and I'll try running the GUI.
    I also have downloaded the source from SVN but haven't built it on my Mac. I got stuck on the first step, which uses cmake. I figured I didn't have cmake because I didn't have the Apple dev tools, but then I installed the dev tools and still don't have cmake. Did you just manually install that? I googled and see that there are some Mac packages for cmake.
  4. #14
    Mar 2009
    Los Angeles
    Oooo.
    The -s parameter to OBD GPS Logger is for the OBD device, not the GPS one. Just run
    Code:
    obdgpslogger --spam-stdout
    And you'll see the gps stuff being reported. That's all there is until you sort your OBD device.
    I'm not actually using gpsdX; I'm using a gpsd that I downloaded and built myself from the gpsd homepage
    I should clarify; By using gpsd, you don't have to configure anything in obdgpslogger to work with the gps; it magically just works.
    Gary (-;
  5. #15
    May 2009
    Great! I passed the next hurdle. I went out to my Jeep and sat there with my Mac, my GPS, and the OBD. I ran
    Code:
    And I instantly saw some GPS output
    Code:
    gpspos=58.304787,-134.410629,59.500000
    Then I added the OBD to the mix:
    Code:
    ./obdgpslogger -s /dev/cu.CANOBDII-DevB-1 --spam-stdout
    And I saw both GPS and OBD data!
    Code:
    >BD reported NO DATA for cmd 10: NO DATA
    GPS acquisition complete
    gpspos=58.304760,-134.410614,64.500000
    temp=43.000000
    rpm=906.000000
    vss=0.000000
    So that is great, it means all my hardware works, at least minimally. So at times I would see the note saying NO DATA for cmd 5 or 10 -- I'll look in the code to see what that means. Also, I tried without success to use the GUI. I launched it, and when I went to choose my OBD dongle, when I select the dongle in list in the dialog box, the application seemed to hang. I have it a long time to process, maybe five minutes, but eventually I force-quit.
    I am now trying the convert log feature. Hmmm... when I click Convert the progress bar says Conversion Progress, but nothing else seems to be happening, no progress is ever shown.
    So in theory, I should be able to forget the command line stuff, launch the GUI, set my GPS and OBD, then press Go, and everything would work. Is that the right idea?
  6. #16
    Mar 2009
    Los Angeles
    Weird problem with selecting the dongle, not sure what's up with that; there's nothing that really happens when you click on the item in the list, all the "magic" happens when you hit go.
    "NO DATA" means that the obd device literally returned the string "NO DATA". Perhaps check that the obd device is plugged in completely? [I've had mine come loose a couple times and cause similar issues]
    Yep, the eventual idea is that once it's all set up, launching the GUI and clicking "go" should be all you need
    One other thing that occurred to me; there's no locking on the serial port; if you attempt to run two loggers at the same time, or [as I have accidentally done], minicom and obdlogger at the same time, then you'll find a lot of garbage being reported.
    Gary (-;
  7. #17
    May 2009
    Hello. I reinstalled Linux and immediately tried to download and build obdgpslogger. (To update my previous statement, I had to install gpsd, libgps-dev, fluid, and cmake.)
    I followed your instructions: mkdir build, cd build, cmake... At this point I got an error, as cmake needs to be told where the source files are, so in my environment it requires cmake ../src. Fine, but when I run that I get this error:
    Code:
    CMake Warning (dev) in CMakeLists.txt:
      No cmake_minimum_required command is present.  A line of code such as
        cmake_minimum_required(VERSION 2.6)
      should be added at the top of the file.  The version specified may be lower
      if you wish to support older CMake versions for this project.  For more
      information run "cmake --help-policy CMP0000".
    This warning is for project developers.  Use -Wno-dev to suppress it.
    That is weird because your CMakeLists.txt file *does* have that command at the top of it. Any idea what the problem might be? Although the Mac builds are useful for me to test the software, in the end it's important to run it on my Linux netbook, which is a better size for having in a car on road trips.
  8. #18
    Mar 2009
    Los Angeles
    That's because the CMakeLists you referenced was the one in ../src/ instead of the one in ../; only the top-level one lists that requirement. It's worth noting that you're exceedingly unlikely to get a successful build if you don't get CMake to run the entire tree starting at the top.
    Try cmake .. instead of cmake ../src/
    I see the issue, though; cmake doesn't want to know where my "source files" are, it wants to know where *its* source file is - ie, the top-level CMakeLists.txt
    Gary (-;
  9. #19
    May 2009
    Question
    Well, I've been having some mixed success. I learned about how to set up bluetooth devices on Linux and I did that. I edited /etc/bluetooth/rfcomm.conf to create rfcomm0 (which is my GPS) and rfcomm1 (which is my OBD). I can do
    Code:
    rfcomm connect 0 &
    rfcomm connect 1 &
    to connect to the two devices, and I get output suggesting that the devices are connected.
    Then I run
    Code:
    gpsd -N -b /dev/rfcomm0
    to start gpsd, and the blue light on the BT359 starts flashing once per second, which means it is connected. At this point I can launch xgps which shows me some GPS data, which means I'm successfully getting location data.
    Then I can run
    Code:
    obdgpslogger -s /dev/rfcomm1 --spam-stdout
    and I see what I saw previously on my Mac: a few lines of basic engine data (temp, throttle, vss) and a line of GPS location data. New data dumps to standard out once per second.
    So that's not bad. The next thing was to run obd2csv, which did produce the file obdlogger.csv, but that file contained only a header row with no data rows. That made me wonder whether or not the data gets logged to the database with the --spam-stdout option.
    In any case, I then opened up the GUI. Like before, I couldn't get it to work. The best I found is that if I show the "raw output" and connect to stderr, then when I click the Go button I see an error about file not found. The error does not specify what file is missing, unfortunately. Do you agree with my inference that something which exists in your environment is missing from my environment?
    I'm making painfully slow progress but I'm very happy to have this basically running on my little Linux netbook. I'll be a lot more interested if I can get all this setup automated better.
  10. #20
    Mar 2009
    Los Angeles
    Definitely shouldn't be a problem. Can you post your obdlogger.db file somewhere? It's a simple sqlite3 database with three tables in it.
    Yeah, Linux bluetooth setting everything up by hand kinda sucks.
    Can you show me the full output from that window?
    Gary (-;
  1. Beta: CCarProject
    By BenjaminS in forum MacCar
    Last Post: 09-27-2006, 01:25 AM
  2. Silverwolf linux frontend
    By intuitionsys in forum Software & Software Development
    Last Post: 12-02-2005, 03:10 PM
  3. Girder for Linux?
    By kbyrd in forum Linux
    Last Post: 08-02-2005, 10:47 PM
  4. the benifits (& drawbacks) of linux
    By turbocad6 in forum Linux
    Last Post: 03-01-2005, 03:02 PM
  5. Linux Login, UPS and Linux Touch Screen
    By polc1410 in forum Newbie
    Last Post: 02-11-2005, 11:43 AM
