Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: How to get this to work on an ARM processor?
  1. #11
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Oh, it's worth noting that this doesn't work with gpsd yet.
    With gps support disabled, obdgpslogger depends on absolutely nothing that doesn't come in your standard C libraries. Once you have that working, I'll help you [or someone else can] get gpsd working.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  2. #12
    Mar 2009
    Los Angeles
    Or, rather than cross-compiling, I read your thread Make fun of the noob; if you have a real flavor of ubuntu 9.04 on there, you might find you just need to do "sudo apt-get install cmake" on the device, and everything will magically turn up. Then you can follow my usual build instructions, but actually run it on the device...
    Gary (-;
  3. #13
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think it worked....
    I tried to make and install and I think it worked. Does this mean it compiled for the Sheeva?
    Code:
    bugbyte@iPlug:~/build/obdgpslogger-0.6$ cmake /home/bugbyte/build/obdgpslogger-0.6
    -- The C compiler identification is GNU
    -- The CXX compiler identification is GNU
    -- Check for working C compiler: /usr/bin/gcc
    -- Check for working C compiler: /usr/bin/gcc -- works
    -- Detecting C compiler ABI info
    -- Detecting C compiler ABI info - done
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    -- Detecting CXX compiler ABI info
    -- Detecting CXX compiler ABI info - done
    -- Couldn't find libgps
    -- Found DBUS: /usr/lib/libdbus-1.so,/usr/lib/libdbus-1.so
    -- Looking for include files HAVE_SIGNAL_H
    -- Looking for include files HAVE_SIGNAL_H - found
    -- Looking for sigaction
    -- Looking for sigaction - found
    -- Looking for signal
    -- Looking for signal - found
    -- Looking for XOpenDisplay in /usr/lib/libX11.so
    -- Looking for XOpenDisplay in /usr/lib/libX11.so - found
    -- Looking for gethostbyname
    -- Looking for gethostbyname - found
    -- Looking for connect
    -- Looking for connect - found
    -- Looking for remove
    -- Looking for remove - found
    -- Looking for shmat
    -- Looking for shmat - found
    -- Found X11: /usr/lib/libX11.so
    -- Found FLTK: fltk_images;fltk;fltk_gl;fltk_forms;/usr/lib/libX11.so;/usr/lib/libm.so
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/bugbyte/build/obdgpslogger-0.6
    bugbyte@iPlug:~/build/obdgpslogger-0.6$ make
    Scanning dependencies of target ckobdinfo
    [  3%] Building C object src/obdinfo/CMakeFiles/ckobdinfo.dir/obdconvertfunctions.o
    [  6%] Building C object src/obdinfo/CMakeFiles/ckobdinfo.dir/obdservicecommands.o
    Linking C static library libckobdinfo.a
    [  6%] Built target ckobdinfo
    Scanning dependencies of target ckobdconfigfile
    [  9%] Building C object src/conf/CMakeFiles/ckobdconfigfile.dir/obdconfigfile.o
    Linking C static library libckobdconfigfile.a
    [  9%] Built target ckobdconfigfile
    Scanning dependencies of target cksqlite
    [ 12%] Building C object libs/sqlite3/CMakeFiles/cksqlite.dir/sqlite3.o
    Linking C static library libcksqlite.a
    [ 12%] Built target cksqlite
    Scanning dependencies of target obdgpslogger
    [ 15%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/tripdb.o
    [ 18%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/supportedcommands.o
    [ 21%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/gpsdb.o
    [ 25%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/obdserial.o
    [ 28%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/main.o
    /home/bugbyte/build/obdgpslogger-0.6/src/logger/main.c: In function 'main':
    /home/bugbyte/build/obdgpslogger-0.6/src/logger/main.c:192: warning: assignment discards qualifiers from pointer target type
    [ 31%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/database.o
    [ 34%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/obddb.o
    [ 37%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/obddbus.o
    [ 40%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/gpscomm.o
    Linking C executable ../../bin/obdgpslogger
    [ 40%] Built target obdgpslogger
    Scanning dependencies of target obd2kml
    [ 43%] Building C object src/kml/CMakeFiles/obd2kml.dir/heightandcolor.o
    [ 46%] Building C object src/kml/CMakeFiles/obd2kml.dir/singleheight.o
    [ 50%] Building C object src/kml/CMakeFiles/obd2kml.dir/obdgpskml.o
    Linking C executable ../../bin/obd2kml
    [ 50%] Built target obd2kml
    Scanning dependencies of target obd2csv
    [ 53%] Building C object src/csv/CMakeFiles/obd2csv.dir/obdgpscsv.o
    Linking C executable ../../bin/obd2csv
    [ 53%] Built target obd2csv
    [ 56%] Generating convertwindow.h
    [ 59%] Generating logwindow.cxx
    [ 62%] Generating gpsdwizard.cxx
    [ 65%] Generating maindisplay.cxx
    /home/bugbyte/build/obdgpslogger-0.6/src/gui/maindisplay.fl:2: unknown version '1.0300'
    Scanning dependencies of target ckobdfl
    [ 68%] Building CXX object src/gui/CMakeFiles/ckobdfl.dir/logwindow.o
    [ 71%] Building CXX object src/gui/CMakeFiles/ckobdfl.dir/gpsdwizard.o
    [ 75%] Building CXX object src/gui/CMakeFiles/ckobdfl.dir/maindisplay.o
    [ 78%] Building CXX object src/gui/CMakeFiles/ckobdfl.dir/convertwindow.o
    Linking CXX static library libckobdfl.a
    [ 90%] Built target ckobdfl
    Scanning dependencies of target obdgui
    [ 93%] Building CXX object src/gui/CMakeFiles/obdgui.dir/loggerhandler.o
    [ 96%] Building CXX object src/gui/CMakeFiles/obdgui.dir/obdgui.o
    [100%] Building CXX object src/gui/CMakeFiles/obdgui.dir/guessdevs.o
    Linking CXX executable ../../bin/obdgui
    [100%] Built target obdgui
    bugbyte@iPlug:~/build/obdgpslogger-0.6$ make install # optional
    Install the project...
    -- Install configuration: ""
    CMake Error at cmake_install.cmake:36 (FILE):
      file cannot create directory: /usr/local/share/man/man1.  Maybe need
      administrative privileges.
    make: *** [install] Error 1
    bugbyte@iPlug:~/build/obdgpslogger-0.6$ sudo make install # optional
    [sudo] password for bugbyte:
    -- Installing: /usr/local/share/man/man1/obdgpslogger.1
    -- Installing: /usr/local/share/man/man1/obd2csv.1
    -- Installing: /usr/local/share/man/man1/obd2kml.1
    -- Installing: /usr/local/share/man/man1/obdgui.1
    -- Installing: /usr/local/bin/obdgpslogger
    -- Installing: /usr/local/bin/obd2kml
    -- Installing: /usr/local/bin/obd2csv
    -- Installing: /usr/local/bin/obdgui
    Want to:
  4. #14
    Mar 2009
    Los Angeles
    That's actually on the sheeva? Awesome stuff, looks exactly right.
    You even have fltk installed, which means that you can run the gui version on a remote system.
    Gary (-;
  5. #15
    Aug 2007
    Northern VA
    Quote Originally Posted by chunkyks View Post
    In case it's not clear, what Gary is saying is that you can launch obdgui on the Sheeva and display it on your mac or PC if you want.
    On a Mac, the simplest is to fire up the X11 server (may need to install it from CD first) and ssh to the sheeva with X11 forwarding enabled. It should "just work" (tm).
    On windows you can use Xming or cygwin for the X server and do the same.
    https://sourceforge.net/projects/xming
    hth
    charles
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Okay, indeed it appears as if I've got obdgpslogger compiled and installed on the Sheeva.
    Code:
    bugbyte@iPlug:/dev$ obdgpslogger -h
    Usage: obdgpslogger [params]
       [-s|--serial[=/dev/cu.OBDKeyPro-DevB-1]]
       [-c|--count[=infinite]]
       [-n|--no-autotrip]
       [-t|--spam-stdout]
       [-p|--capabilities]
       [-o|--enable-optimisations]
       [-l|--serial-log=<filename>]
       [-a|--samplerate[=1]]
       [-d|--db[=./obdlogger.db]]
       [-v|--version] [-h|--help]
    Now, I need to find FTDI for the Sheeva so I can plug in my OBD cable?
    BTW, I plugged in my OBDPRO Scantool and it did NOT show up in /dev. Will it show up without being plugged into the car?
    Want to:
  7. #17
    Aug 2007
    Northern VA
    run this before plugging it in
    Code:
    sudo tail -f /var/log/messages
    It should be identified (and the ftdi module should be on the sheeva) and most likely will say it is assigned /dev/ttyUSB0.
    You can also check if the ftdi module is loaded by running
    Code:
     lsmod | grep ftdi
    Report back and we should be able to help from there.
  8. #18
    Mar 2009
    Los Angeles
    If you're using leopard, you already have it. You don't need to "fire it up", it will magically do the right thing when you ssh with X forwarding enabled. I cannot strongly enough urge you to update X11 on leopard if you're using it, though. Apple aren't pushing out updates through software update, but you can download an official[ish] update package from here: http://xquartz.macosforge.org/trac/wiki
    Really, the best thing to do is have a real linux install. I'm using VirtualBox with great success; if you don't have a PC with linux installed on it already, I strongly recommend installing Ubuntu 9.04 in a virtualbox. Life just gets easier, the same way that it does if you want to talk to a Windows box; the simplest way to do it is with another Windows box.
    Have fun,
    Gary (-;
  9. #19
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by cgalpin View Post
    Code:
    bugbyte@iPlug:/dev$ sudo tail -f /var/log/messages
    Jun 16 12:42:29 iPlug -- MARK --
    Jun 16 13:02:29 iPlug -- MARK --
    Jun 16 13:22:30 iPlug -- MARK --
    Jun 16 13:42:30 iPlug -- MARK --
    Jun 16 14:02:31 iPlug -- MARK --
    Jun 16 14:22:31 iPlug -- MARK --
    Jun 16 14:42:32 iPlug -- MARK --
    Jun 16 15:02:32 iPlug -- MARK --
    Jun 16 15:22:32 iPlug -- MARK --
    Jun 16 15:42:33 iPlug -- MARK --
    Code:
     lsmod | grep ftdi
    Here's what I got. Curious. I had to hit Ctrl-C to break out of it.
    Code:
    bugbyte@iPlug:/dev$ lsmod | grep ftdi
    bugbyte@iPlug:/dev$
    Want to:
  10. #20
    Mar 2009
    Los Angeles
    See what lsmod shows on its own, without piping it into grep.
    When running tail -f /var/log/messages, did you not get anything when you plugged and unplugged the device? What about if you run "dmesg" after?
    Gary (-;
  1. Aopen i945gtt-vfa Users: Processor Question
    By cyu06 in forum General Hardware Discussion
    Last Post: 11-01-2006, 06:22 PM
  2. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 08:22 PM
  3. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  4. Mobo and processor choices
    By quickshot56 in forum General Hardware Discussion
    Last Post: 10-20-2004, 07:16 PM
  5. Frodo: Work Harder, Work Faster..
    By hevnsnt in forum FrodoPlayer
    Last Post: 09-24-2004, 04:09 PM
