That worked! Sweet! Someone who knows what they're doing!
How did you find out about that package? I need to know how to find that stuff.
Hey bugbyte...
Try this:
apt-get install libftdi1
My Nearly Complete Car:
http://www.mp3car.com/vbulletin/show...ed-car-pc.html
Micro Control Center... Control Your Car Across the Internet
http://www.mp3car.com/fusion-brain/1...-internet.html
Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
http://paulfurtado.com/
Want to:
Yeah, you'll need to use svn, sorry :-/
Cool. That's what you end up with if you start from this qemu starting pointarmv5tejl
EDIT: If anyone out there does try the starting point above, you need these additional packages to build obdgpslogger with all features:
Although the only thing you *need* out of that lot, to make obdgpslogger do *something*, is cmakeCode:libfltk-1.1-dev fluid cmake libdbus-1-dev gpsd libgps-dev
Gary (-;
OBDGPSLogger, for logging OBDII and/or GPS data
OBDSim, an OBDII/ELM327 software simulator
mp3car forums: obdgpslogger, obdsim
okay debian has a cool interface to apt-get called aptitude.
to install it, do apt-get install aptitude
now when you have an idea of what a package will be called, you can do:
aptitude search package
I found that by doing aptitude search ftdi
it returns a list of packages and their descriptions.
You can then install them normally.
PaulF: If you want to save space, you don't need aptitude; this does the same thing
Gary (-;Code:apt-cache search {thing}
What worked? Do you now get your device recognized? I expect the answer is no because this package doesn't contain the ftdi kernel module
But if it does, please let me know and I'll run out to my car and see if it helps my problemCode:$ dpkg -L libftdi1 /. /usr /usr/lib /usr/lib/libftdi.so.1.13.0 /usr/share /usr/share/doc /usr/share/doc/libftdi1 /usr/share/doc/libftdi1/changelog.gz /usr/share/doc/libftdi1/README /usr/share/doc/libftdi1/copyright /usr/share/doc/libftdi1/changelog.Debian.gz /usr/lib/libftdi.so.1![]()
Oh linux, how you always find another way.
Good to know. I haven't used a debian based distro in a long time.
I just remembered aptitude from the old debian command line installer and it came in handy when apache wasn't called apache22 =)
I intend on sticking a 4gb pen drive into this thing to give it extra space if need be. I'm realizing though, it's terribly difficult to use up 512mb of space on bare-bones command line linux install. =)
I'm going to check what I can do this weekend/next week to get GPS and OBD working.
I'll make a how to at some point too.
This little sheeva plug is quite powerful. It's snappy and is working very well. SFTP transfers are instant. Copied phpMyAdmin to it in 20 seconds.
The thing runs pretty warm though. I plan on taking it out of its case and putting it in a project enclosure with a 5 volt POL power supply and some small fans though so that it's car-ready. I can't wait to crack this thing open.
I think I may be more excited about it than my car pc.
Want to:
Heh. apt-cache predates aptitude by many years, I believe - in this case, aptitude is that other way :-)Oh linux, how you always find another way.
Your new toy for today is apt-rdepends:
Have fun,Code:chunky@mills:~$ apt-rdepends -r libftdi1 Reading package lists... Done Building dependency tree Reading state information... Done libftdi1 Reverse Depends: ftdi-eeprom (>= 0.2-9) Reverse Depends: libftdi-dev (= 0.12-1) Reverse Depends: openocd (>= 0.0+r655-1ubuntu1) Reverse Depends: tucnak2 (>= 2.11-3) ftdi-eeprom libftdi-dev openocd tucnak2 chunky@mills:~$
Gary (-;
EDIT: Bugbyte, that isn't a suggestion to install any of those packages reported by apt-rdepends; it's something that smarter people than I [sup PaulF, cgalpin] may find useful for figuring out how to get this working.
I'm attempting to build the kernel module with the driver found here:
http://www.ftdichip.com/Drivers/VCP.htm
however i have huge amounts of errors which i cannot work out. They seem to be regarding C syntax but I highly doubt thats the real problem.
Why do we even need ftdi?
