Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
Thread: How to get this to work on an ARM processor?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Okay, I'm a complete Linux noob, but if you're willing to help me along, I'd like to make getting OBDII GPS Logger the first app I have working on my Sheeva plug.
    It runs Debian Linux 9.04. I know that to get this to work I'll have to do two things:
    1. Get a version of FTDI that works or can be compiled for the ARM.
    2. Compile GPS logger for the ARM.
    I've got a bunch of Linux books on the way. I presume that I need to install gcc (which I have) and can use the make command to compile this for the ARM?
    Is this the right way to start?
    Want to:
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Sounds about right.
    OBD GPS Logger has been tested on x86_64, x86, and PPC [so far]. I strongly suspect there's no reason it can't work on ARM too.
    Sheevaplug - that means you won't be needing the GUI? Probably makes life easier. The GUI is the only C++ thing in the codebase, too - the rest of it should work with just about any old C compiler you can hunt down.
    If you want the GPS logging working [I assume you do], you'll want to get gpsd installed too. obdgpslogger links against libgps [from gpsd] to get the gps data.
    Unless you enable dbus [it's off by default, for this application you don't want it], obdgpslogger depends on nothing other than libgps, it calls nothing that isn't in standard libc - it *should* be as simple to build as anything out there. Even if you can't get gpsd working, obdgpslogger will gracefully fallback to not linking with gpsd, and just log obd data.
    Are you cross-compiling, or building directly on the device? If you're building directly on the device [much, much, much easier if you can], you'll need gcc and ideally cmake. If you can't get cmake, then I'll write you a couple custom makefiles to get the job done.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Mar 2009
    Los Angeles
    Also, I just checked out that SheevaPlug. I want one! Looks Sweet :-)
    Gary (-;
    Jan 2008
    Dartmouth, MA
    And if you really have trouble, I should be getting my sheeva by the end of the week. Next weekend I'll be able to give some pretty serious help. ;-)
    Plus Friday is the last day of school for me.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Aug 2007
    Northern VA
    Paul, how do you know yours is coming? Did you get an email letting you know? I have not heard back since I ordered.
    Bugbyte, have you tried following this 9.0.4 howto? ALl the ubuntu steps should be the same as long as the ARM repo has the same packages, and you should be able to just build it on board (and you have the memory space)
    http://www.mp3car.com/vbulletin/obdi...igure-run.html
    hth
    charles
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I'll give it a go! I haven't had a chance to really focus on this but last time I tried to cmake, it told me it didn't know what that command was and I was lost.
    Want to:
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by cgalpin View Post
    I got an email saying:
    We just wanted to update you and let you know that your order ****** has shipped via FedEx Ground Service.
    Here is your Tracking Number (if available): ***************
    Thanks for shopping at GlobalScale Technologies.
    GlobalScale Technologies Customer Service
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yeah, for awhile they were running a backorder. I took mine about 6 weeks to arrive and I finally got an email telling me it had shipped and when it would arrive. It also said they had stopped taking orders for awhile until they caught up.
    Want to:
    Mar 2009
    Los Angeles
    Yeah, you need the cmake package installed for that to work.
    I've just been browsing the sheeva development stuff; quick question, do you use a cross-compiler, or are you doing something different? If you're using a cross-compiler, cmake gracefully supports what they call "toolchain" files. I can write one for you so that you can compile obdgpslogger on your PC [with your sheeva toolchain installed] using the cmake you already have on that PC.
    Gary (-;
    Mar 2009
    Los Angeles
    OK, cross-compiling happy fun time. I'm going to assume you're using Linux as your development desktop, since those are the tools provided by plugcomputing:
    1) Download the relevant development kit from plugcomputing. Specifically, go to resources->downloads, click on Compilers, then download "SHEEVAPLUG HOST SW SUPPORT PACKAGE FOR LINUX"
    2) Extract it all. I'm going to set up some "standards" for you to adhere to now that will work for you:
    Code:
    unzip SheevaPlug_Host_SWsupportPackageLinuxHost.zip
    cd LinuxHost
    bzip2 -cd ./gcc.tar.bz2 | tar -xvf-
    sudo mv gcc /usr/local/sheeva-toolchain
    gzip -cd "./Linux Host Filesystem - rootfs.tar.bz2" | tar -xvf-
    sudo mv rootfsv1.0 /usr/local/sheeva
    2a) Make sure you have cmake installed. If you're using ubuntu, "sudo apt-get install cmake".
    You now have all the tools you need to cross-compile stuff for sheeva. Now to try compiling.
    3) Make sure you have the latest svn of obdgpslogger, as I've added a Sheeva toolchain file to it:
    Code:
    svn co svn://svn.icculus.org/obdgpslogger/trunk obdgpslogger
    4) Set your environment to let cmake find the sheeva toolchain:
    Code:
    PATH=/usr/local/sheeva-toolchain/bin:$PATH; export PATH
    5) And build!
    Code:
    mkdir build; cd build
    cmake -DCMAKE_TOOLCHAIN_FILE=../cmakemodules/Toolchain-sheeva.cmake ..
    make
    See what happens. Assuming all goes to plan, you will find the important binary you need in ../bin:
    Code:
    $ file ../bin/obdgpslogger
    ../bin/obdgpslogger: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, not stripped
    Well, that was easy. [comparatively :-D]
    Gary (-;
  1. Aopen i945gtt-vfa Users: Processor Question
    By cyu06 in forum General Hardware Discussion
    Last Post: 11-01-2006, 06:22 PM
  2. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 08:22 PM
  3. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  4. Mobo and processor choices
    By quickshot56 in forum General Hardware Discussion
    Last Post: 10-20-2004, 07:16 PM
  5. Frodo: Work Harder, Work Faster..
    By hevnsnt in forum FrodoPlayer
    Last Post: 09-24-2004, 04:09 PM
