Results 11 to 20 of 23
Thread: Cannot initialize DBUS obdsim generator
  1. #11
    Aug 2007
    The above command didn't seem to work, even after I fixed the syntax error to the following:
    Code:
    dbus-send --system \
     --dest=org.openice.fbd.fusionbrain \
     --type=signal \
     /org/openice/fbd \
     org.openice.fbd.fusionbrain.AnalogValueChanged \
     int32:11 \
     int32:2600
    I opened up qdbusviewer in my desktop kde installation, downloaded/installed the latest SVN, and opened up obdsim prior to using the dbus-send command above, but nothing ever came up.
    I'm looking for a way to receive a dbus signal from obdgpslogger every time it registers a new entry into the log so that I can display it on screen, so the above command will tunnel it through obdsim and end up in obdgpslogger, correct?
    Thank you for your patience, Gary! I feel like I'm getting real close here.
  2. #12
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    OK, I'm confused; could you exactly explain your situation? Are you in a car with an OBDII device, using obdgpslogger to read it? And then you want obdgpslogger to signal on dbus whenever it sees a new value?
    If so... you don't want to use OBDSim for that; obdgpslogger already does it, all on its own. Check obddbus.c for the exact interface/path/member and the actual message
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  3. #13
    Aug 2007
    Quote Originally Posted by chunkyks View Post
    I am building a GUI that will be able to send/receive DBus messages to different areas of the OS. One of the areas deals with reading the OBD information and displaying it on screen. I think that obdgpslogger would help me out in achieving this really well.
    The only reason why I want obdsim to work right now is because the pc isn't hooked up to the car yet, so I would like to simulate some DBus data for obdgpslogger to consume and then throw a DBus signal that my GUI can pick up.
    Hope this makes more sense.
  4. #14
    Mar 2009
    Los Angeles
    Ooooooooo
    In that case, just use "obdsim -g Random -o"
    Assuming obdgpslogger was build with dbus enabled, that should be all you need to actually generate dbus signals from obdgpslogger. If all you want to see it *something* output from obdgpslogger, then that should be sufficient
    Gary (-;
  5. #15
    Mar 2009
    Los Angeles
    Or, if you want to see some more realistic figures, download http://icculus.org/obdgpslogger/down-to-vista.db and use
    Code:
    obdsim -g Logger -s down-to-vista.db
    You can also use obdgui to connect to the pty that obdsim announces, and verify that your dbus signal reader is reading the right thing by checking that obdgui and your gui say the same thing.
    Gary (-;
  6. #16
    Aug 2007
    I'm sorry if I wasn't so clear from the start. I get ahead of myself sometimes.
    I just tried both examples and I didn't pick anything up in qdbusviewer or dbus-monitor. I didn't find any output errors either. Is there anything else I should try? I am positive I compiled obdgpslogger with both DBUS switches on, but I'm going to try that again and get back to you.
  7. #17
    Mar 2009
    Los Angeles
    I haven't yet implemented introspection, so in qdbusviewer you won't see "obdgpslogger" in the "services" panel on the left, it'll be one of the :somenumber ones.
    In dbusmonitor, make sure you're looking at the system bus, /a la/
    Code:
    dbus-monitor --system
    Of the two dbus switches in cmake, the important one for this is "OBD_ENABLE_DBUS"; the other is just to enable the dbus generator for obdsim. I would suggest a rebuild from scratch, to be sure:
    Code:
    cd obdgpslogger-top-level-svn-checkout
    rm -rf build
    mkdir build; cd build
    cmake -DOBD_ENABLE_DBUS=ON ..
    make
    Also at risk of sounding ridiculous, what OS are you running? All this should work under cygwin ["should" as in "I haven't tried it myself"], but probably not mingw/msys [yet]. I know it works on OpenSolaris 2009.06 , ubuntu 8.10 and 9.04, and OSX 10.4 and 10.5.
    Gary (-;
  8. #18
    Aug 2007
    I just tried re-compiling/installing and nothing changed. I found the entry in qdbusviewer, but it only produced an error:
    Error: Cannot introspect object / at :1.87: org.freedesktop.DBus.Error.AccessDenied (Rejected send message, 1 matched rules; type="method_call", sender=":1.86" (uid=1000 pid=11297 comm="/usr/bin/qdbusviewer ") interface="org.freedesktop.DBus.Introspectable" member="Introspect" error name="(unset)" requested_reply=0 destination=":1.87" (uid=1000 pid=11333 comm="obdgpslogger --serial /dev/pts/3 --db ./obdgpslogg")))
    My carpc has a custom Ubuntu Jaunty 9.04 i386 build and my desktop is also a Jaunty version but in AMD64.
  9. #19
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by bkuri View Post
    I don't think chunky_ks has introspection working yet... Your best bet would be to watch for the signals coming through dbus-monitor --system.
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  10. #20
    Aug 2007
    Quote Originally Posted by kev000 View Post
    Eureka! I totally forgot to check with dbus-monitor... Thanks man
    Now I just need to learn how to grab DBus events without depending on introspection... Any clues?
