Results 1 to 4 of 4
Thread: What config files to save when reinstalling Linux
    May 2009
    I run obdgpslogger on my netbook because that is a convenient computer to use in the car. Now I want install a new flavor of Linux on the netbook, but I want to be able to use obdgpslogger after that. I remember going through a lot of setup in several config files, but I don't remember which ones, or where they are.
    Specifically, I remember setting up bluetooth device descriptions, and probably some other things too.
    Chunky, or somebody else, can you tell me which files those are? If you can, perhaps I could script the backup process, which could be an addition to the obdgpslogger suite.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Well, the stuff that I'm aware of:
    1) /etc/udev/rules.d/{something}
    Should be a single file that you created, probably ftdi.rules or something?
    2) Purge brltty and libbrlapi [although they may be a little less intrusive regarding libftdi now]
    3) There's maybe some gpsd config stuff, but really it's not hard to re-do that one
    4) If you've used it, ~/.obdgpslogger
    - And if you haven't used it and weren't aware of it, check the manpage for "dot-obdgpslogger" (5) :-D
    Assuming you're using ubuntu, packages to reinstall starting from scratch off the top of my head [to enable all features]:
    Code:
    sudo apt-get install cmake build-essential libgps17 libgps-dev gpsd libdbus-1-dev zlib1g-dev subversion libfltk1.1-dev fluid make g++ gcc
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    May 2009
    Can you also remind me which file has the bluetooth device descriptions?
    EDIT: I found it! /etc/bluetooth/rfcomm.conf
    Mar 2009
    Los Angeles
    /etc/bluetooth/rfcomm.conf ?
    Gary (-;
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. XP System Builder
    By SFiorito in forum WinNT Based
    Last Post: 03-19-2007, 06:13 AM
  3. The LOW Risk Linux Adventure...
    By grepzen in forum Software & Software Development
    Last Post: 11-08-2004, 10:12 PM
  4. Squirrel POS touchscreen????
    By odleon in forum LCD/Display
    Last Post: 10-03-2004, 10:38 AM
  5. mp3/ogg player for Linux?
    By mpfreeze in forum Software & Software Development
    Last Post: 12-16-2002, 10:35 AM
