Results 1 to 7 of 7
Thread: On gpsd, obdgpslogger, and udev hotplug
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    So, finally I have obdgpslogger and gpsd both working with udev hotplug, on ubuntu 9.04
    My USB OBDII devices are FTDI.
    My USB GPS device is pl2303.
    1) Making gpsd work
    a) Copy /lib/udev/rules.d/40-gpsd.rules to /etc/udev/rules.d/40-gpsd.rules
    b) Edit /etc/udev/rules.d/40-gpsd.rules. Comment out the line for idVendor 0403 and idProduct 6001, and modify the two pl2303 lines so that the permissions will let gpsd access it:
    Code:
    # Prolific Technology, Inc. PL2303 Serial Port
    SYSFS{idVendor}=="067b", SYSFS{idProduct}=="2303", SYMLINK="gps%n", MODE:="0666", RUN+="/lib/udev/gpsd.hotplug.wrapper"
    # ATEN International Co., Ltd UC-232A Serial Port [pl2303]
    SYSFS{idVendor}=="0557", SYSFS{idProduct}=="2008", SYMLINK="gps%n", MODE:="0666", RUN+="/lib/udev/gpsd.hotplug.wrapper"
    c) Edit /lib/udev/gpsd.hotplug.wrapper
    Take out the line
    Code:
    . /lib/udev/hotplug.functions
    and put this there instead:
    Code:
    wait_for_file() {
            [ -e "$1" ] && return 0
            local count=0
            while sleep 1; do
                    let count=count+1
                    if [ $count -gt 60 ]; then
                            return 1
                    fi
            done
    d) sudo dpkg-reconfigure gpsd
    Launch on boot - yes
    Leave the automatic device list empty
    Should gpsd handle devices automatically - yes
    Options to gpsd: "-F /var/run/gpsd.sock"
    2) Make obdgpslogger hotplug work
    a) Put this in /etc/udev/rules.d/40-ftdi.rules
    Code:
    SUBSYSTEM!="tty", GOTO="ftdi_rules_end"
    ACTION=="add", SYSFS{idVendor}=="0403", SYSFS{idProduct}=="6001", RUN+="/usr/local/bin/obdgpslogger -ms /dev/%k"
    LABEL="ftdi_rules_end"
    b) Configure obdgpslogger to do what you want
    Edit /etc/obdgpslogger [if it doesn't exist, just create it]. Set it to put the logfile in the right place:
    Code:
    log_file=/media/usbthumb/carlog.db
    If you have a device that defaults to 38400 instead of 9600 [eg, an OBDLink], then you also need to put that in the config file:
    Code:
    baudrate=38400
    The obdgpslogger half is covered in a bit more detail in doc/auto_launch in your svn checkout
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    great job. I'll do this inside LinuxICE to make things easier.
    will obdgpslogger automatically create the path to the db?
    Former author of LinuxICE, nghost.
    Current author of nobdy.
    Mar 2009
    Los Angeles
    Oops, forgot to add a thing about gpsd permissions. Fixed.
    Gary (-;
    Mar 2009
    Los Angeles
    OBDGPSLogger doesn't automatically create a path to the db. The default is "./obdgpslogger.db". If you want it set to something else, that's what the config file /etc/obdgpslogger is for.
    Gary (-;
    Mar 2009
    Los Angeles
    Oh. And if gpsd.hotplug.wrapper doesn't exist on your system at all, try this one:
    Code:
    #! /bin/bash
    # $Id: gpsd.hotplug.wrapper 4669 2008-01-21 15:07:00Z esr $
    #debian addition:
    [ ! -r /etc/default/gpsd ] || . /etc/default/gpsd
    [ "$START_DAEMON" = "true" ] || exit 0
    [ "$USBAUTO" = "true" ] || exit 0
    if [ "$ACTION" == "remove" ] ; then
      if [ $(echo $DEVLINKS | grep -q /dev/gps) ] ; then
        exec /lib/udev/gpsd.hotplug "$ACTION" "$DEVNAME"
      fi
      exit 0
    fi
    # . /lib/udev/hotplug.functions
    wait_for_file() {
    	local count=0
    	while sleep 1; do
    		let count=count+1
    			return 1
    		fi
    	done
    # wait for /usr & /var to be mounted
    wait_for_file /usr/bin/python && \
    wait_for_file /var/run && \
    Gary (-;
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Configured everything except for the obdgpslogger part. I don't have /etc/obdgpslogger in my directory (step 2b).
    What does that mean? I've never run obdgpslogger before?
    Want to:
    Mar 2009
    Los Angeles
    It doesn't create /etc/obdgpslogger by default, just create one yourself. [Added that to the top post]
    Gary (-;
  1. Now with tasty hotplug
    By chunkyks in forum OBDII GPS Logger
    Last Post: 07-09-2010, 11:46 AM
  2. Getting OBDGPSlogger to run on the Sheeva Plug
    By Bugbyte in forum OBDII GPS Logger
    Last Post: 04-22-2010, 05:49 PM
  3. udev rules for scantools
    By tripzero in forum OBDII GPS Logger
    Last Post: 08-10-2009, 11:31 PM
