Quote:
Opening serial port /dev/com10, this can take a while
Successfully connected to serial port. Will log obd data
Your OBD Device claims to support PIDs:
PID: [column] human_name
00: [unknown] PIDs supported 00-20
01: [unknown] Monitor status since DTCs cleared
03: [fuelsys] Fuel system 1 and 2 status
04: [load_pct] Calculated LOAD Value
05: [temp] Engine Coolant Temperature
06: [shrtft13] Short Term Fuel Trim - Bank 1,3
07: [longft13] Long Term Fuel Trim - Bank 1,3
0B: [map] Intake Manifold Absolute Pressure
0C: [rpm] Engine RPM
0D: [vss] Vehicle Speed Sensor
0E: [sparkadv] Ignition Timing Advance for #1 Cylinder
0F: [iat] Intake Air Temperature
10: [maf] Air Flow Rate from Mass Air Flow Sensor
11: [throttlepos] Absolute Throttle Position
13: [o2sloc] Location of Oxygen Sensors
14: [o2s11] Bank 1 - Sensor 1/Bank 1 - Sensor 1 Oxygen Sensor Output Voltage / Short Term Fuel Trim
15: [o2s12] Bank 1 - Sensor 2/Bank 1 - Sensor 2 Oxygen Sensor Output Voltage / Short Term Fuel Trim
1C: [obdsup] OBD requirements to which vehicle is designed
2 trouble codes set [MIL is off]
Error: P0014
Error: P0600
