Results 1 to 10 of 11
Thread: New Release: 0.10
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    New Release: 0.10
    Version 0.10 (released 2009-10-31)
    Logger, conf: Ability to adjust serial baudrate
    Initial add of ftdi-pty proxy for systems without ftdi-sio
    conf: Add ability to write config file back to disk
    ftdipty can modify config file for obdgpslogger
    Logger, conf: Ability to configure logfile name
    Logger: Gracefully exit if a serial write fails
    Logger,doc: Hotplug docs
    Logger: cygwin compilation fixes
    Sim: Don't build socket generator without getaddrinfo symbol
    Logger: If obd device isn't available, exit [would log gps before]
    Have fun, all
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Aug 2009
    Doesn't compile with Cygwin:
    [ 92%] Building C object src/sim/CMakeFiles/obdsim.dir/simport.o
    Linking C executable ../../../bin/obdsim.exe
    CMakeFiles/obdsim.dir/simport.o:simport.c.text+0xe): undefined reference to `_posix_openpt'
    collect2: ld returned 1 exit status
    make[2]: *** [../bin/obdsim.exe] Error 1
    make[1]: *** [src/sim/CMakeFiles/obdsim.dir/all] Error 2
    make: *** [all] Error 2
    Uncommenting line 36 and commenting line 37 of \src\sim\simport.c makes the error go away.
    Edit: Added screen shot of codes from my Lumina. I know for sure the codes are P0300 and P1406, I guess you can sort of see one of them?
    Mar 2009
    Los Angeles
    Yeah, I'm aware of that. I need to check for the posix_openpt symbol. The insulting bit is that posix_openpt is available in the header, and the other necessaries [eg posix_grantpt] are just fine. It's just that the symbol isn't publicly available in the cygwin C library itself.
    You found the fix I'm going to use; the code will look like
    Code:
    #ifdef HAVE_POSIX_OPENPT
    int fd = posix_openpt(O_RDWR);
    #else
    int fd = open("/dev/ptmx", O_RDWR);
    #endif //HAVE_POSIX_OPENPT
    Just gotta set up the build system to do it.
    Heh, that's the svn that I only committed last night. Among other things, it doesn't gracefully handle multiple ECUs...
    You're getting NO DATA; that's what happens when the OBD device literally responds with the string "NO DATA". Please could you run obdgpslogger with "-l seriallog.txt" [dash little-ell] and post the seriallog?
    Thanks,
    Gary (-;
    Aug 2009
    Zipped it up in case the browser decides to get creative with a .txt file that has binary contents. I did svn sync and rebuilt just now, then ran it.
    Attached Files Attached Files
    Mar 2009
    Los Angeles
    OK, two things:
    1) Please could you do an svn update [and probably an "svn revert src/sim/*", to back out your modifications], and see if it compiles on cygwin for you now? I'm explicitly checking for posix_openpt in the build system, and using open("/dev/ptmx") if that's not available.
    2) Also, do an svn update; I *was* sending "0300" [ie mode+cmd], which is incorrect; mode 0x03 does not need a cmd. Perhaps that will fix the problem? If not [for that matter, even if it does], please could you upload a fresh seriallog?
    Hope all that helps,
    Gary (-;
    Aug 2009
    Reverted src/sim/* and everything compiles in Cygwin now. Did svn update but it's still getting NO DATA. Edit: Whoops ran obdgpslogger.exe instead of ./obdgpslogger.exe ... new seriallog now. Edit #2: Hah! Bluetooth port shut down before I ran the command and I didn't notice. Re-ran again and now it's printing out the codes:
    Opening serial port /dev/com10, this can take a while
    Successfully connected to serial port. Will log obd data
    Your OBD Device claims to support PIDs:
    PID: [column] human_name
    00: [unknown] PIDs supported 00-20
    01: [unknown] Monitor status since DTCs cleared
    03: [fuelsys] Fuel system 1 and 2 status
    04: [load_pct] Calculated LOAD Value
    05: [temp] Engine Coolant Temperature
    06: [shrtft13] Short Term Fuel Trim - Bank 1,3
    07: [longft13] Long Term Fuel Trim - Bank 1,3
    0B: [map] Intake Manifold Absolute Pressure
    0C: [rpm] Engine RPM
    0D: [vss] Vehicle Speed Sensor
    0E: [sparkadv] Ignition Timing Advance for #1 Cylinder
    0F: [iat] Intake Air Temperature
    10: [maf] Air Flow Rate from Mass Air Flow Sensor
    11: [throttlepos] Absolute Throttle Position
    13: [o2sloc] Location of Oxygen Sensors
    14: [o2s11] Bank 1 - Sensor 1/Bank 1 - Sensor 1 Oxygen Sensor Output Voltage / Short Term Fuel Trim
    15: [o2s12] Bank 1 - Sensor 2/Bank 1 - Sensor 2 Oxygen Sensor Output Voltage / Short Term Fuel Trim
    1C: [obdsup] OBD requirements to which vehicle is designed
    2 trouble codes set [MIL is off]
    Error: P0014
    Error: P0600
    Mar 2009
    Los Angeles
    Code:
    >0100
    NO DATA
    >0101
    NO DATA
    That makes no sense at all.
    Thus, I suggest you check that the OBD dongle is plugged in properly and hasn't wiggled loose.
    Gary (-;
    Mar 2009
    Los Angeles
    I'm really pleased that it builds on cygwin now, though. Of course, I'd also like to know if it actually *works*, but building is a good start :-)
    Gary (-;
    Aug 2009
    Indeed! See above post, I edited it twice
    Mar 2009
    Los Angeles
    Getting there! Sorry this is so difficult, I really appreciate your patience on the topic :-)
    Also, could you upload another seriallog, [for -p, with the error output]? Those errors aren't the same as the ones you said you know they should be... Which may be an artifact of some other changes I made earlier this evening. Lots of development has gone on tonight, and I'm started to get tired.
    Thanks,
    Gary (-;
  1. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  2. Replies: 65
    Last Post: 07-23-2008, 03:03 AM
  3. Radio control with iBus ???
    By jeep642 in forum Car Audio
    Last Post: 10-02-2007, 12:51 PM
  4. Replies: 8
    Last Post: 04-02-2007, 12:09 AM
  5. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
